Old 12-23-2014, 01:55 PM
SLICK1 SLICK1 is offline
Question Best Hi-Port porters?
Not trying to start a battle or debate, just trying to be pointed in the right direction of the person known to be the most knowledgeable with these heads, it can be hand porting or CNC program?
Thanks in advance and Happy Holidays to all.....
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 12-23-2014, 02:49 PM
ponjohn's Avatar
ponjohn ponjohn is offline
SD has a good port even though they don't advertise it.
Also Jim Robertson comes to mind.
Old 12-23-2014, 03:51 PM
jm455ho's Avatar
jm455ho jm455ho is offline
Second for Jim Robertson. I know he's had at least two sets go through his hands.
www.hobracing.com
Old 12-23-2014, 04:02 PM
Dan Barton has several sets at least he has done.
Old 12-23-2014, 04:05 PM
GTO's Avatar
GTO GTO is offline
You prob. seen my flow sheet before but here it is again. For around $3500 back then, it was a good deal.
Runner Up Q16 Norwalk 2013!
Old 12-23-2014, 07:25 PM
slowbird's Avatar
slowbird slowbird is offline
Dan Barton hands down!
Old 12-23-2014, 07:40 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
KRE, SDPerf and BES can make them go. I do not have experience with others.
Old 12-23-2014, 08:12 PM
x2, all 3 are very good with that head. Hard to say who is BEST
Old 12-23-2014, 09:13 PM
Scott Stoneburg's Avatar
Not to steal the thread, but Are your heads standard pushrod location?
Old 12-23-2014, 09:36 PM
GTO's Avatar
GTO GTO is offline
As far as I know. No shafts either. Harland Sharp rockers and a stud girdle. ... Econo build!
Old 12-23-2014, 10:26 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
NICE!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
Old 12-23-2014, 10:52 PM
John Langer's Avatar
John Langer John Langer is offline
I wouldn't even mention the first 2 with BES...
Old 12-23-2014, 11:24 PM
KRE offers a 1075 hp NA option on their site. I'm not aware of SDPerf, BES or yourself offering more?
Old 12-23-2014, 11:52 PM
slowbird's Avatar
You know anyone with that engine?
Where did KRE's HP engines qualify in Tom's race at Norwalk?
Old 12-24-2014, 12:56 AM
I do not know anyone with that engine. What I do know is if KRE offers the power level it will deliver, I've been on their pump. Do you offer more power with their parts? I don't know anything about Tom's race.
What I do know KRE is the quickest Pontiac 1/4 mile with Pontiac power. They also have the quickest Pontiac powered door car on the planet.
What is your point?
Old 12-24-2014, 01:14 AM
David Holmberg's Avatar
Gaby did Ryan's Hi ports, BES would be my other thought.
Jim Robertson or Dan are also excellent choices.
Old 12-24-2014, 02:20 AM
R 70 Judge's Avatar
Jim Robertson does nice work. See my signature. Keep in mind it's a pump gas street/strip engine with rockers/stud girdles and not a high compression race piece.
James
1970 Trans Am
Old 12-24-2014, 05:53 AM
slowbird's Avatar
What are your performance goals?
Old 12-24-2014, 07:11 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Truth!
[email protected]. 3460#s
Old 12-24-2014, 07:36 AM
Why not lay down some criteria first for what the so called BEST is first, are we only going to consider the fastest et and mph per engine cid and car weight?
