Old 01-01-2015, 12:12 PM
machota154 machota154 is offline
Default 1998 Trans Am with a Butler Performance 462 Pontiac Motor
This is my 1998 Trans Am that I am installing a 462 Pontiac motor along with a 4L80E.
Name:	20140911_174331 (800x450).jpg
ID:	385985   Click image for larger version
Name:	20140911_174342 (800x450).jpg
Old 01-01-2015, 12:20 PM
I used a BMR turbo k member that utilized pedestal mounts. I used a combination of their mount and mine to make it work.
Name:	20140901_123258 (800x450).jpg
ID:	385992   Click image for larger version
Name:	20140901_123516 (800x450).jpg
ID:	385993   Click image for larger version
Name:	20140901_130242 (800x450).jpg
ID:	385994   Click image for larger version
Name:	20140901_130415 (800x450).jpg
Old 01-01-2015, 12:35 PM
Had to lower the steering rack about an inch to clear the oil pan. Guess I'm going to have to get a bump steer kit to straighten the rack geometry out.
Name:	20140901_130341 (800x450).jpg
ID:	385998   Click image for larger version
Name:	20140901_130353 (800x450).jpg
ID:	385999   Click image for larger version
ID:	386000   Click image for larger version
Name:	20140708_190904 (450x800).jpg
ID:	386002   Click image for larger version
Name:	20140708_190916 (450x800).jpg
Old 01-01-2015, 07:47 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
This is pretty cool! Should really move when its done!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 01-01-2015, 08:12 PM
Default 462
Thank you, I can't wait to get it done.
Old 01-03-2015, 11:39 PM
Default Springs
I installed my QA1 shocks and springs. UMI upper and lower control arms.
Name:	20140529_212605 (800x450).jpg
ID:	386264   Click image for larger version
Name:	20140529_212718 (800x450).jpg
ID:	386265   Click image for larger version
Name:	20140529_212748 (800x450).jpg
Old 01-04-2015, 10:37 AM
Txbobcat Txbobcat is offline
That ought to be a mover when you get it done.
Old 01-04-2015, 11:52 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Now that's what GM should have kept doing! Real cool, go pro the first beating please!LOL
Old 02-01-2015, 10:04 PM
I finally made my steering shaft. Since I had to lower the steering rack, the shaft would not reach the rack. So I made my own. It is made from the ends from the 4th gen and the telescopic part from an Astro van.
ID:	389138   Click image for larger version
Old 02-01-2015, 10:35 PM
JSPONT's Avatar
cool, yeah the little things are time consuming.
Old 02-01-2015, 10:50 PM
grivera's Avatar
grivera grivera is offline
Nice work! Great to see old muscle in a newer ride!
Will Rivera
Old 02-01-2015, 11:34 PM
72blackbird 72blackbird is offline
AWESOME! Payback is a bi-atch, LS fans!
Old 02-02-2015, 09:41 AM
2002Z4CSS's Avatar
Are you going to be able to run an air cleaner on that engine?
1971 Pontiac GT-37
Old 02-02-2015, 08:59 PM
Not much of one !!!!
I am going to use a low profile air plenum, then into air filters.
Hopefully !!!!
Old 02-02-2015, 11:20 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
How is distributor access? Can you get the cap off?
The rule of thumb for suspension design is the steering tie rods should run parallel to the lower control arm throughout the suspension's travel to minimize bump steer.
http://www.pontiacpower.org/
Old 02-02-2015, 11:46 PM
Distributor cap can be removed with no real problem. There is more room there than you would think.
As far as the steering rack goes, I lowered the rack about 1 inch. Hopefully the adjustable bump steer kit will help.
Old 02-03-2015, 09:29 AM
Subscribing...
I was thinking about doing this type of a swap, the V6 bodies are plentiful, affordable, and still in pretty good condition.
What kind of rear are you planning to use?
Any chassis stiffening/bracing?
Please keep up with posting progress and any issues, etc you may have. Many are interested.
Old 02-03-2015, 10:25 AM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Ditto what HWYSTR455 said, many of us are interested in this project.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
Old 02-09-2015, 04:32 PM
quicksilver97ta's Avatar
Thumbs up
^^^ This!!! LOL!!!!
Old 05-17-2015, 06:22 PM
ChiefPonch ChiefPonch is offline
Awesome! You just saved me from posting a new thread asking about a Pontiac engine in a late model. I've been pondering it for quite some time. Whenever I finally get started on this project, I will have a ton of questions. Mine will be a well-built 400 street car (hoping to clear 500 horse) mated to a T-56. I hope you don't mind me bothering you and sending a couple of messages. I'll try to keep it to a minimum. Your thread and pics have answered many of my questions already & I am subscribed. Thanks for your help!
