Old 01-21-2015, 07:32 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Default Does anybody epoxy in the turtle?
I'm curious how most people attach the turtle to the Victor 4500 intake. I've heard some run a bolt thru the middle and I've heard some use epoxy. If epoxy, what kind and how sure are you some doesn't come loose and go thru the engine? It would "appear" that the turtle in theory should help. I can't imagine the flat plenum floor working better?!?
I have a 463, 330'EHeads,roller, 1050 Shaker Holley.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 01-21-2015, 07:34 PM
slowbird's Avatar
slowbird slowbird is offline
Throw the turtle away
Old 01-21-2015, 08:05 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
^this^
[email protected]. 3460#s
Old 01-21-2015, 08:08 PM
mike leech's Avatar
mike leech mike leech is offline
^^What they said^^
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 01-21-2015, 08:58 PM
bluegoat65 bluegoat65 is offline
It comes loose. BOLT IT from the bottom.
Old 01-22-2015, 01:10 AM
Does it not performance at all?
Old 01-22-2015, 01:11 AM
Butler had told me it was best bolted from the bottom but if it doesn't help performance, I won't fool with it. You are saying the intake works better with a flat floor?
Old 01-22-2015, 07:46 AM
I have made them fully out of epoxy set on top of 6 10/32 machine screws threaded into the bottom of the Plenum, and in regards to a Victor manifold a 3/4" tall one will always help the fuel distribution pattern and also to turn the air mass into the runners,that being said the issue after that is using a spacer for a taller Plenum to regain the lost Plenum volume sucked up by the turtle!
On a 470 cid or larger motor with heads flowing over 315 cfm@28" this is not something to over look if your trying to bang out every last bit of power!
Old 01-22-2015, 01:39 PM
SLICK1 SLICK1 is offline
Exclamation
X2, I had mine epoxied for years, it came loose, I removed it and the car went faster, it liked more plenum in the intake, so don't install it...
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 01-22-2015, 03:26 PM
Saves me the trouble. Thanks!
Old 01-23-2015, 09:27 AM
LiL Jack's Avatar
You would be better off doing a little work to the top of the manifold. If it's a dominator take out the clover leaf and blend the roofs of manifold back more.
Also a HVH tapered spacer have picked up on the cars I have put them on just be mindful that the carb doesn't get too close to the hood.
Old 01-23-2015, 11:35 AM
I have a one inch spacer so my plenum area should be fine. I also have a big hood scoop so clearance isn't an issue. Just wanted to play with the intake while I'm waiting to get the motor back. Any pics on the area to work on?
Old 01-23-2015, 04:46 PM
Thumbs up
Same set up 2in. HVH tapered spacer, intake ported by Dr. Js, removed turtle, carb done by Dean Nickerson!
(see it in action)
Old 01-24-2015, 12:11 PM
grandville455's Avatar
That's what I did to mine, was removed the Cloverleaf, and blended runners best I could. Its amatuer hour,lol
Darby
M/T 275/60 ET SS Drag Radial
Old 01-24-2015, 10:54 PM
Looks good.
Old 01-25-2015, 12:59 AM
slowbird's Avatar
Pic of my Victor from awhile ago, i highly doubt you'll find any fast guys running a turtle.
Old 01-25-2015, 11:12 PM
Why do all these intakes come with the waffle pattern in the plenum? Seems counter productive.
Old 01-26-2015, 07:43 AM
That pattern helps to re- introduce puddled up fuel into the air stream.
Excess fuel on the manifold floor is the main reason for a blast of black smoke seen as some cars lunch if not also from too much pump shot!
