Old 03-14-2015, 12:04 PM
Mr. P-Body Mr. P-Body is offline
Smile New RACE head info now available
Dave Wilcox has released flow numbers and some pics of his new Ram Air V-based billet race head. This is unlike anything Pontiac people have seen before. They outflow any currently advertised heads (peak). And though based on the valve layout of Ram Air V, that's where the similarities end. NOT a "tunnel port", this head employs modern trapezoidal "tall" ports.
The real news is the low-and mid-lift numbers. Good builders know, peak numbers sell product. Average numbers make power. We're more about making power... These heads will be able to be used on anything from a 500 HP streeter or bracket engine, to near 4K HP blown/alcohol.
These heads have been produced for the new engine for Goateus Maximus. They'll be "mapped" and variations will be available.
headsandmanifolds.com
We're going back on safari! (hunting elephants...)
Jim
Old 03-14-2015, 12:43 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Cool!! My old Super Chiefs just keep getting more and more behind the times.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 03-14-2015, 12:54 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Good to hear from you Jim[Mr.P-body, you too JT]. This sounds like a winner of a head. Can't wait to see pics, and results!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 03-14-2015, 02:52 PM
I kind of like their cross ram too!
Old 03-14-2015, 03:30 PM
Yep, Skip, Crossram is cool (in Plastic) and has a bunch of mods put into it that we have had in our modded crossrams for many years.
They Ported a BG Tri-Power for me that was 1st Class work by Dave W.
Old 03-14-2015, 08:35 PM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
Awesome Jim! Think it is time to replace my 62's??? Lol
Old 03-14-2015, 11:24 PM
Jim
Nice addition to the arsenal! Dave knows how to move some air.
Pushrod offset? Valve length?
You sure about the "streeter" capabilities though? Billet heads drilled for coolant usually dont flow enough coolant in critical areas for street cruisin' or road race use. Most drag cars running billet are towed to lanes and back down return road unless running alcohol.
Old 03-19-2015, 01:09 PM
roadrage david roadrage david is offline
Damm those are a seriues quantem leap forward..
Old 03-20-2015, 04:53 PM
10second70GP's Avatar
10second70GP 10second70GP is offline
This is great to hear !
