Closed Thread
Old 04-12-2015, 09:35 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Default Dick Fulton's CV-1 Engine makes 1095HP !!!
... i would like to thank everyone involved in this build, but most importantly Dick Fulton, for allowing me the opportunity to show what these heads can do, and I'm very thankful for that ...
... we made 1095hp @ 8000 and 757 ft.lbs @ 7100 rpm, with good power past the peaks, we ran the engine well over 8k most of the day and pulled to 8500rpm several times and the engine never blinked, we did have some minor leaks that kept the vacuum to around 6 inches at the peak, so we believe 1120hp is in hand once the vacuum issue is resolved, but the torque curve was extremely flat and I'm sure once this baby gets a sniff of the funny stuff it's going to make some big power ...
... Dick's engine is a purpose built 13 to 1 N20 Combo, so we obviously are excited to get some compression n/a versions together using the CV330/Raceplate heads and Roland Racing's CNC ported cast tunnel ram which was used on this engine, and while we have high hopes for the even larger development ports (CV345, CV365, CV385) we can't wait to see what some compression will do using the same top end as Fulton's ...
ID:	395222   Click image for larger version
ID:	395223   Click image for larger version
Old 04-12-2015, 11:40 AM
Congrats to all involved!
Nice hint of potential these heads have for NA power!
I too cant wait to see NA build numbers with these ports, let alone the larger ports you've already developed.
Norwalk should be interesting!
Old 04-12-2015, 11:49 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Congratulations! The long wait was well worth it.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 04-12-2015, 12:17 PM
carl455 carl455 is offline
Congratulations Dick and Bill. Glad u stayed on your path.
Old 04-12-2015, 12:46 PM
... thank you Carl ...
Old 04-12-2015, 02:46 PM
bruce driggers bruce driggers is offline
Congrats to Dick , Bill , Jim , & anyone else involved , knew the potential was there , glad to see ya'll got it done !!
Old 04-12-2015, 04:17 PM
So where is the thread with the predicted Horsepower numbers started a while ago?
Old 04-12-2015, 04:37 PM
... here is one of the pulls from yesterdays session ...
https://youtu.be/H52x3DjJEv4
Old 04-12-2015, 04:39 PM
... Dick or myself never started one ...
Old 04-12-2015, 05:02 PM
blueghoast's Avatar
That's bad a$$, Congrats to you and all that worked on this.
That's one Sirius piece.
GT.
Old 04-12-2015, 06:29 PM
GREATGTO's Avatar
GREATGTO GREATGTO is offline
Sounds awesome guys. Exhaust looks killer.
Car Craft Garage.
Automotive Restoration
Old 04-12-2015, 06:43 PM
bankbook's Avatar
bankbook bankbook is offline
Awesome job Bill, Jim,Dick et al!
I have been off the boards for a while so it is good to see a real potent Pontaic come to life.
Looks like it will shape up to be a good season.
Congrats again.
Doc
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 04-12-2015, 06:47 PM
JSPONT's Avatar
JSPONT JSPONT is offline
How much will you be squirting? Congrats!
Old 04-12-2015, 07:12 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
WOW
Congrats to Dick, Bill and everyone involved.
Kevin
Old 04-12-2015, 07:24 PM
GT.
Congrats again.
Doc
Originally Posted by 535 tall deck View Post
WOW
Kevin
... thanks guys, we feel this is a good starting point for the new development level heads and we have some cool stuff in the works, i really look forward to maximizing the CV-1 design and figure out just how much power we can squeeze from them ...
... here is a dyno graph of our best pull, thought it was worth a look ...
Old 04-12-2015, 09:18 PM
Torque curve is hardly curved... Nice!
Old 04-13-2015, 08:06 AM
and congrats on hitting 1000 HP @ 7000 RPM.
Old 04-13-2015, 09:15 AM
Gary H's Avatar
Gary H Gary H is offline
Default Cubic Inches
First off, congratulations! Lots of thought and hard work to pull this off. I may have missed it in a earlier post but was size engine is it?
Old 04-13-2015, 09:47 AM
Its a 541. 13:1 compression, cammed for N2O.
Old 04-13-2015, 12:42 PM
Region Warrior's Avatar
Think that's the smoothest sounding pull I ever heard.
Nice graph. N2o should really increase the torque numbers.
Congrats.
Closed Thread
