Old 03-31-2015, 01:34 AM
michael j michael j is offline
Default Unleaded
after reading these posts went down stairs and checked on my 74 SD. Nothing saying unleaded gas.
  #4662
Old 04-03-2015, 11:08 AM
sd455hota's Avatar
sd455hota sd455hota is offline
Default 74 SD TA
Originally Posted by sd455hota View Post
I have an engine from a 74 auto SD car. Complete/original including block, carb, intake, heads, alternator, dist, manifolds, egr, valve covers, etc. Looks like only the water pump has been changed. No starter. VIN on block is 24N1604--. If your close let me know. Be glad to send this engine to it's original home. Or I would purchase the 'home' and bring it here to the engine.
Including a pic of a stamp found on the block. I found it interesting. I don't remember seeing this on other engines.
Posting the PHS for the engine I have here. TA, Blue, blue with white seats sold new in Chicago. Would sure like to like to find the car.
Name:	PHS 74 SD Engine.jpg
  #4663
Old 04-04-2015, 03:31 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
would have really liked that vin, "455"
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #4664
Old 04-11-2015, 04:53 PM
Alvin's Avatar
Alvin Alvin is offline
Cool
OK to post about 1974 SD's here in the "70-73 Section" right?
Congrats to Houston MECUM auction buyer Matthew Wagoner
Lot S115. 1974 TA Super Duty Automatic sold @ $70,000
https://www.mecum.com/lot-detail/HA0...uty/Automatic/
  #4665
Old 04-17-2015, 05:41 PM
Red Goat's Avatar
Red Goat Red Goat is offline
Default Starter
Hey guys, does an 1108436 starter dated 3B13 seem too early for a 1st week of June built SD?
All my original engine components have date codes that are pretty spread out on this motor. Only thing I need is a starter and hope this one will work.
  #4666
Old 04-27-2015, 03:13 PM
Alvin's Avatar
Thumbs up
This just in - Boss 302 v SD-455 Shootout in latest HMM
  #4667
Old 04-27-2015, 04:02 PM
SD73's Avatar
SD73 SD73 is offline
Nice race. It doesn't say, but can we expect at that wait the SD was an AC car with lower higher gears too? Either way, both pulled in some decent times.
  #4668
Old 04-27-2015, 04:14 PM
I guess I'm confused, I though that the cars in pure stock could only use what was available for use in that year of car. ?? It says the T/A used a set of 390:to 1 rear gears & that set was not available for the car in 74 or 73 for that matter. The biggest gear set would have been 342: to 1 & the gear for the boss would have been a set of 390: to 1 & that was the only gear for it. What gives?? Also the T/A used a 2400 stall speed converter which stock was a 12" that was a 1400 stall speed for that car. I think to be fair also the cars should have been matched a little closer with the T/A being a 4 spd. with no A/C. But it seems the mag. was a bit biased about the match up. If they were closer the T/A would have won hands down.
  #4669
Old 04-28-2015, 12:46 AM
70ram4 70ram4 is offline
HI guys after several years of seeing and reading about these SD trans ams, I think its time I look into trying to buy one. I will be looking to buy a nice driver as I plan on driving and enjoying the car, but would consider a numbers matching project car, if im priced out of the market. I've always been a GTO guy, so any advise on what to look for, good colors, typical problem areas, anything at all to help out this trans am noob? I hope to pick your brains a little and put out a wanted ad. Thanks again
  #4670
Old 04-28-2015, 07:11 AM
The Boss's Avatar
The Boss The Boss is offline
Paul, you missed the boat on the red 74 you were offered a couple of years ago!
And go racin' in the street.
  #4671
Old 04-28-2015, 08:23 AM
muscle_collector's Avatar
I would suggest a green, white, red, or blue one if your getting a trans am
  #4672
Old 04-28-2015, 10:06 AM
Alvin's Avatar
Previous lost in transition
  #4673
Old 04-28-2015, 10:54 AM
Chris don't remind me. Muscle collector. I never would have figured white in the mix. But they do look nice in that color too.
  #4674
Old 04-28-2015, 01:35 PM
threefidee's Avatar
threefidee threefidee is offline
That is mostly true. Gears however if your car can handle it, you can use it. It 60 fts. hard ! No AC on that car.
Regarding the converter, I believe you can nothing smaller than a 12"
The problem we had with matchups was there were a few that did not show and replaced at that day so we had to move a few cars around.
Jody
1979 Pontiac Trans Am
- W72 400 - 4speed
- WS6
- Heritage Brown
- Air Conditioning
  #4675
Old 04-28-2015, 02:33 PM
Alvin's Avatar
Talking
Well, if one REALLY wanted to open up the color-pallet they could've gone w the SD Formula option ordering, right? Like "old yeller" for ex.
  #4676
Old 04-29-2015, 12:32 PM
darrylta darrylta is offline
Location: West BY GOD Virginia, a refugee from Maryland
The TA I bought in 73 was white, with a small bird on the nose
The 74 was blue without the bird and no AC
Darryl
  #4677
Old 04-29-2015, 06:43 PM
mine is in pieces, but what it will look like.
ID:	396496   Click image for larger version
ID:	396497   Click image for larger version
FREEDOM ISN'T FREE
  #4678
Old 04-29-2015, 09:24 PM
Nice looking car!
  #4679
Old 04-30-2015, 07:17 AM
Judge273's Avatar
Judge273 Judge273 is offline
74 Yellow SD formula survivor is a sweet ride too!
Mike/Illinois
  #4680
Old 05-01-2015, 05:56 AM
74 SD455 Formula 74 SD455 Formula is offline
Thanks Mike......
ID:	396586   Click image for larger version
