The line I'm looking for is the line that goes across the front of passenger side of the engine. It bolts front of the engine and the thermostat housing and looking four blue 4 hose ported vacuum switch. See pic thanks manny
Starting at post 241...On the vacuum switch.
http://216.178.81.108/forums/showthr...755425&page=13 http://www.ebay.com/itm/301249077287...%3AMEBIDX%3AIT Is the line your looking for goes over to the charcoal canister part way then connects via vacuum hose and on the other end connect to the carb. If so I may have one but no promises. |
Thanks for the info on the ported vacuum switch. I have a ac delco replacement its white so i was going to attempt to paint it if i couldnt find the right one. That is the line im looking for. If possible can you send a pic if you can locate yours. Thanks
I have a used switch which I don't know if it works , needs cleaning up.
Does it have part number stamped on top?
How much for the switch
I don't see a part # on top.
I would like $25 for it which includes mailing. |
Looked on the old parts car today and the line is missing. Its like it didnt have one, it was a vacumm line from the canister up to the carb.
Ok thanks for looking
You still looking for these parts, Machota100? I know I have the metal line and pretty sure I have the vacuum switch too. Off a '79 TA 400.
Gary |
It took a little time but I found everything. Im looking for a mint set of camel tan seatbelts and a 4 speed center console now.
