#241
#242
Neither of the cars involved in this race currently run e-heads. They are great heads for the money and support good hp numbers. The design has also been out for 20 years and everyone has had that much time to maximize what they can do. Im sure if you gave both men 20 years to make more power than they are now It would happen. It will happen over time. The e-head has been maxed out without boost which they are not using. This being said port volumes/valve angle/ect must be changed to keep moving forward. Pissing the other man off often times creates the drive to do something you normaly wouldnt just to prove you can. We all gain from that.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#243
posts #1 and #13 dispell that myth the plumber girls have been spewing for years- http://forums.maxperformanceinc.com/...d.php?t=659827 hurt 1 spark plug and valve after 80+ full on nitrous passes in the low 8's @ 3300lbs-nothing else... from the horses mouth
"He who laughs last, laughs loudest" |
#244
Also, no timeslip, no video = didn't happen! |
#246
Every time i have tuned my ehead combo up it has made more. We've gained well over 150hp over the once thought max of eheads in the last 15 months. Stock valve angles and placement. You might want to sit down for this.....but i can see another 25-30 if i want it. A little costly but its there to take if I wanted it.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#247
Im not taking away anything from those running e-heads. I have 2 sets myself. Maybe Im looking at it like this. The potential for hp is greater in the more current design. If I had nothing and was investing in a engine combination to maximize the amout of hp that could be made I wouldnt go the e-head rout in 2015.
#248
Do you specialize in port development or are you just another machinist with a die grinder porting heads and intakes? I'm honest enough to say even I can make improvements with a die grinder and sand rolls but NO WAY am I a head porter nor am I claiming I could out do your work. 1100 HP NA Pontiac as a nitrous build(with the n2o off) compared against an NA Pontiac build with same ci or larger with over 3 points more compression is splitting hairs??? Really??? Cam timing events totally unfavorable to optimum NA requirements, manifolding, headers etc.. Really??? Just maybe you ought to find out who else uses the dyno Dick uses. Maybe you want to find out who witnessed results. Maybe find out what Dicks track reults were with his E-heads compared to numbers from same dyno. Others results from same dyno. Its OK for you to tell us a dyno number, but somehow anything from the CV camp is a lie? Dont get me wrong, not diminishing anyones Pontiac 1100+ hp NA build(not many regardless of head choice and they benefit all of us eventually), nor am I out to diminish your customers results. I do however look at what an entire build is and judge it accordingly. They are all the sum of what they are. To suggest nearly 4 points compression and same or greater cubes at higher rpm is "splitting hairs" is about as misleading as it gets. Its as if you are assuming the average reader in this forum isnt smart enough to see the difference or know that a power adder motor is a completely different build than an NA combo. |
#250
... and still another retarded statement, just hilarious how you turn a damaged plug & a dinged seat into ... " he burnt the engine up " ... ... Robin Roberts has never burned a single piston or head gasket from his CV-1 N20 engine, not once, anyone doubts that, then ask Robin yourself and see what he tells you ... |
#251
... just a nice pic update ...
#253
I figured you all would be at the track today! What is taking so long?
Tic toc tic toc |
#254
#255
... did i say we weren't ... |
#256
#257
#258
I think if he gets it together for Norwalk the fastest cv-1 head will be Bad69bird. That f2 does wonders for any head! ( maybe faster on e heads! LOL just kidding)
#259
... PM me and I'll make sure you get in touch with him ...
| Closed Thread |
