Closed Thread
Old 07-04-2015, 08:13 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Smile
Originally Posted by KO View Post
Brian 69 Firebird
BWAHAHAHAHAHAHAHAHAHAHAHAH
I needed a good laugh.
[email protected]. 3460#s
  #282
Old 07-04-2015, 08:15 PM
LiL Jack's Avatar
I still offer to pay the entry fee for the first CV headed car that enters the HU/NA race at Norwalk!The offer has been out there for what?4 years now?Tom
Maybe give them the back tire and the leave to make it a little more fair.
  #283
Old 07-04-2015, 08:20 PM
GREATGTO's Avatar
GREATGTO GREATGTO is offline
You would think billet heads would have an advantage versus heads with water jackets since you have more room to put ports where you want. As far as Brian's car Id like to know if he blows it up again will it be the heads fault? Whenever he has trouble its somehow the heads fault yet he is still running them. Lets get an answer before it happens?
Car Craft Garage.
Automotive Restoration
  #284
Old 07-04-2015, 08:26 PM
badgto's Avatar
badgto badgto is offline
If Brain does come out and runs a bad azz number and keeps it healthy will you ride his coattail because its a cv-1 head?
  #285
Old 07-04-2015, 08:33 PM
LiL Jack's Avatar
My heads have water in them.
  #286
Old 07-04-2015, 08:34 PM
LiL Jack's Avatar
More like swing from his nuts.
  #287
Old 07-04-2015, 08:59 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Correction! Brian has UT-1's.........UTTTF!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
  #288
Old 07-04-2015, 09:18 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... LMAO !!! ...
  #289
Old 07-04-2015, 09:25 PM
Really. A SB Ford with 2 stages was running those numbers ay the same weight years ago.
I would hope they could do better than a 412 cid Ford Small Block engine (with a much bigger engine and 3 stages). Lets see some 7.40s.
John Force went 3s with a Ford plastic body with a Mopar engine which is just as relevant on this site
1) The Ford has Nitrous (2 stages)
Fulton has Nitrous 3 stages
2) The Ford had a Dry Sump System
Fulton has a Dry Sump System
3) The Ford was running a Canted Valve "Old School" Yates head
Fulton is running a canted valve head.
4) The Ford was running a 10.5 W tire
Fulton probably has something better years later.
5) The Ford as was said was running basically a small engine (with rpm)
Fulton is running a much larger engine within 500 rpm of the Ford engine's rpm
6) Compression ratio is similar if you believe the posts on the board.
So how do these specs resemble a John Force plastic bodied vehicle with a Mopar engine?
  #290
Old 07-04-2015, 09:26 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Dude he's talking to you too. lol
  #291
Old 07-04-2015, 10:02 PM
KO KO is offline
no real Pontiac enthusiast gives a damn about what some Ford runs
1000s of max effort Fords out there, only a dozen or so all out Pontiacs
"old school" heads with 50 years of development compared to street heads worked over
a real comparison would be an FE Ford vs. Pontiac...not even close
1989 Automotive Hall of Fame Inductee
  #292
Old 07-04-2015, 10:19 PM
GREATGTO's Avatar
I will brag about it as much as anyone else running cv1 heads, meaning none. I like or don't like people based on the individual, not what kind of car he runs or which heads he has.
People like to come on here and talk crap about Robin who is one of nicest and most decent people to post on the forums. They could at least wait for him to be here to defend himself.
Those who like to be aholes and play politics are irrelevant on anything they do or don't do.
Car Craft Garage.
  #293
Old 07-04-2015, 10:21 PM
GREATGTO's Avatar
Tom should spend more time on ford forums, why does he live on a Pontiac site?
Car Craft Garage.
  #294
Old 07-04-2015, 10:49 PM
GREATGTO's Avatar
So you wouldn't have any problem letting your car run for several minutes then racing? It is a street car still right?
Car Craft Garage.
  #295
Old 07-04-2015, 11:03 PM
mike leech's Avatar
mike leech mike leech is offline
Originally Posted by BruceWilkie View Post
Fultons combo is NOT unlimited budget! More money than a street strip car? Sure, but no way unlimited budget.
At what weight and CI is this Buick? Is it NA? How is this relevant to a Pontiac discussion?
Do you specialize in port development or are you just another machinist with a die grinder porting heads and intakes?
I'm honest enough to say even I can make improvements with a die grinder and sand rolls but NO WAY am I a head porter nor am I claiming I could out do your work.
1100 HP NA Pontiac as a nitrous build(with the n2o off) compared against an NA Pontiac build with same ci or larger with over 3 points more compression is splitting hairs??? Really??? Cam timing events totally unfavorable to optimum NA requirements, manifolding, headers etc.. Really???
Just maybe you ought to find out who else uses the dyno Dick uses. Maybe you want to find out who witnessed results. Maybe find out what Dicks track reults were with his E-heads compared to numbers from same dyno. Others results from same dyno.
Its OK for you to tell us a dyno number, but somehow anything from the CV camp is a lie?
Dont get me wrong, not diminishing anyones Pontiac 1100+ hp NA build(not many regardless of head choice and they benefit all of us eventually), nor am I out to diminish your customers results.
I do however look at what an entire build is and judge it accordingly. They are all the sum of what they are.
To suggest nearly 4 points compression and same or greater cubes at higher rpm is "splitting hairs" is about as misleading as it gets.
Its as if you are assuming the average reader in this forum isnt smart enough to see the difference or know that a power adder motor is a completely different build than an NA combo.
Write this in the dust on your dash. If i went n20 single carb........1130hp. Youre over estimating the differences effect on power.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #296
Old 07-05-2015, 12:51 AM
All bs a side, if both parties show it should be a great day for the Pontiac faithful.
DF is bringing a bad 69 bird with very nice power topped with CV-1 heads.
LJ is bringing a killer GTO with ba Visner billet heads and intake.
LJ has demonstrated quick times as well as DF. Pick your camp, that's fine. But if this race happens it's the most anticipated race in the last few years.
Good luck to both camps and let the baddest machine win. It's going to be good!
  #297
Old 07-05-2015, 07:36 AM
Elarson's Avatar
Elarson Elarson is offline
I'm looking forward to this race happening. My biggest hope is that both combinations exceed the naysayers expectations. Beyond that, I don't really care who wins.
Eric
  #298
Old 07-05-2015, 09:29 AM
GTOGEORGE's Avatar
Eric
DITTO!!
GTO George
  #299
Old 07-05-2015, 11:23 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Default Apples to Oranges
It is sort of apples and oranges. 1/8 mile car vs 1/4 mile car. If Jack wins to the 1/8, and Fulton wins to the 1/4, what did it prove? It proved both guys have bad azz cars that I wish I could afford and race. It's like a prise fight, talk the chit, after the fighters hug and say good fight!
  #300
Old 07-05-2015, 11:40 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Can't wait this should be fun!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Closed Thread
