Old 07-19-2015, 05:57 PM
nogto nogto is offline
Default Console wiring harness
I have a new MH wiring harness for the console shift indicator. The original wiring harness was removed from my 69 Lemans auto console before I had it. The new harness is gray wire. What color wire am I looking for from the dash harness?
Old 07-20-2015, 08:12 AM
2002Z4CSS's Avatar
Another gray wire that is has power on it when the headlights or parking lights are on.
1971 Pontiac GT-37
Old 07-20-2015, 10:17 AM
Thanks but i found a more specific answer searching under clocks. Turns out that the clock light and the console indicator light connectors are identical and fit together. Both connectors are clear plastic series type with a gray wire. Not to be confused with the clock power which is an orange wire with a blue connector.
Old 07-20-2015, 09:35 PM
MD79TA MD79TA is offline
Something about your answer just seems condescending . If you know the answer why ask... Sorry just had to get that off my chest Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 07-21-2015, 08:59 AM
I looked for a long time under console wiring but no one seemed to know. It is not specified in the wiring diagram either. I continued to look in electrical after I posted and found the answer so I thought I would share it. Just a timing thing, sorry if it seemed condescending. . I appreciate py forums because the answer is always there somewhere
