Old 07-23-2015, 06:42 AM
rad400 rad400 is offline
Default oil psi
Is 20 Psi at idle to low goes up to 50-60 while driving. 406 #12 heads Crower 60210 cam.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 07-23-2015, 07:05 AM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
No.
Karl
Old 07-23-2015, 07:15 AM
shaker455's Avatar
Conrad,
What oil you running and what type of sender & where is it located?
Old 07-23-2015, 07:32 AM
Valvoline ZR 50w I firget on the sending unit lines I think close to the headers. not sure what name brand sending unit is.
Conrad
Old 07-23-2015, 07:39 AM
shaker455's Avatar
I meant elec or mech gauge?
Usually up next to dist is most accurate location & I personally like mech gauges over elec
Old 07-23-2015, 07:58 AM
steve25 steve25 is online now
Even 5 psi will keep bearings afloat at hot idle, the issue is if the pressure comes up fast enough as the motor revs up, 8 to 10 psi per 1000 rpm to be on the safe side of spinning bearings.
Keep a close eye on this relationship!
Old 07-23-2015, 11:39 AM
MescaBug's Avatar
MescaBug MescaBug is offline
I got +- 20 psi at idle when engine is hot. Goes up to 40-60 while driving. All my cars.
Old 07-23-2015, 01:40 PM
Schurkey Schurkey is offline
Valvoline ZR 50w
Anyone besides me think that's terrible for a 50-weight oil? The pressures listed are fine...for 10W30. Fifty-weight is another story.
What oil pump? What are the bearing clearances? Any indication of excess oil at the rockers?
Old 07-23-2015, 02:45 PM
David Jones's Avatar
Good point.
50wt at cold start up should put up a pretty big number at idle.
Old 07-23-2015, 03:01 PM
JLMounce JLMounce is offline
I run about 12 psi at hot idle (700rpm) and 40-60 during cruise around 2000rpm. 10w30 with zddp additive.
I would think a 50 weight would show more pressure.
-Jason
1969 Pontiac Firebird
Old 07-23-2015, 03:07 PM
Chris65LeMans's Avatar
Your numbers are exactly how mine behaves using 20W50 Valvoline racing oil. I've found that different viscocities of oil don't affect my pressure dramatically. Increasing my idle got me from 5 psi at idle to 20. (15 when very hot or getting off the freeway.)
As others have said before, that's fine. You could pull the engine, get in there and investigate, but there's really no need to.
Old 07-23-2015, 07:09 PM
Jeff mech. gauge.
Conrad
Old 07-23-2015, 07:12 PM
Pontiac Performance Author
The Factory service manual says the engine should make rated pressure by 2600 RPM.
The factory warning light came on @ 5-7 PSI. You're good.
Old 07-23-2015, 07:22 PM
At idle that would be right in line with the old 10psi per 1000rpm wouldn't it...........
Karl
Old 07-23-2015, 07:56 PM
Tim Corcoran's Avatar
Your oil pressure is normal for a classic Pontiac
Tim Corcoran
