#861
Car looks great. I'm glad you've got things sorted out and that it's running strong and cool.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
#862
What a difference! She is a beauty Bob.
1972 Formula 455HO 1979 W72 Fire Am 1975 455 4 speed TA |
#863
Wow Bob (& Dave), just WOW!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#864
Ready for Norwalk? Doug, Craig and other big names will be there...
Mike/Illinois |
#865
Yeah, pretty close to ready. The car is close to done, and I've got the cigars and your favorite moonshine. I look forward to seeing everyone.
#866
See you there Bob. I won't have a car there, I'll just have to look for yours.
#867
Read back through and realized I read Judge273's post and saw "Norwalk", but heard "Dayton/TA Nats" in my mind. Regretably I will not make Norwalk, but will be in Dayton. Sorry I won't get to meet you Mike, and see Craig, Judge, Doug and many other friends.
On another note, the Gold Car went to the alignment shop yesterday and got the front end dialed in. These cars handle incredibly well. |
#868
I might put mine on the alignment machine soon & see how much positive caster I can get out of it without impacting the camber angle. I think that might improve it even more!
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
#869
I'm undecided on replacement tire size now for our '78...replacing 245/60/15's I installed back to (stock WS6 size?) 225/70/15, 245, or 255/60/15's Bob, appears you're running the OEM size tires, yes? |
#870
My thinking is I would remove all the shims from the rearward side of the upper control arm shafts then add shims to the frontward side until I got the camber in spec. then see what side of the car has the least amount of caster & shim the other side to match. That way both side would be the same & be the most positive caster I could get without offset parts. this is just my thinking, haven't looked that close yet. For all I remember, It might be out of adjustment room already. I have seen some cars have no shims at all & still not have enough +caster. maybe a slightly sagged inward frame?
#871
Just realized I had my front & rear shims backwards in thought above, but you guys know what I meant anyway
![]() Here's the specs that are in my machine.
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA Last edited by 68ragtop; 07-30-2015 at 05:39 PM. |
#872
On another note, the Gold Car went to the alignment shop yesterday and got the front end dialed in. These cars handle incredibly well.[/QUOTE]
Yes, the Trans Ams and even the F bodies in general were way ahead of their time when it came to handling. Even today they don't drive like an old car when compared with a current model.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1996 Trans Am WS6 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 |
#873
No shows this year... Goatless BW Bob Uncle Jeff & Me There's always next year - sure not missing the hangover this morning and there was no line for my shower.
#874
Alvin, do you know what those alignment specs were compared to the ones above? Not trying to steer the thread, but was curious how they compared to what I have.
#875
Alvin - they are OEM size tires in a Polysteel repop. I too would like to see the Herb Adams specs. Below is a photo of the Gold Car alignment sheet. Amazingly, after completely disassembling the entire front end and replacing every bushing and balljoint, all that needed adjusted was the Toe. We took careful measurements before disassembly and that certainly helped.
#876
I have a tendency to fool around for a couple hours getting them as close as I can, because I can Not that it would make much a difference tho. I'll bet Herb adams bumps the positive caster some & for sure a little negative camber. That would improve handling, but at the cost of some uneven tire wear. How many shims do your upper arms have in place? I'm sure you already have pictures of that somewhere in your thread?
#877
"Our '77 T/A goes from bumbling to bravo with some help from Nerb Adams VSE." by Tomas A. Demaro reprint of HPP original article.This should get you started. I do have the specific '78 specific WS6 Adams specs archived somewhere in my files...IIRC the above alignment specs are the same as recommended by Herb Adams...and should be enough alignment wise to get you in the ball park. IIRC these are the specs used on my former '78 WS6 w 255/60/15 that handled like it was on rails. Note the "steering lash adjustment" recommendation. Hope this helps. Edit: Image below of source publication cover of quoted specs from article above. Provided for those who may desire to obtain their own copy. |
#878
Bob,
Not sure if you have heard, but Herb will be at the Nats and will be conducting a suspension seminar. I also have two of his catalogs and can make some copies of some of the technical portions and bring them with me if you would like.
#879
Why not share the tech here?
#880
I can, just didn't know if there were any legalities involved.
