Old 07-31-2015, 07:46 PM
Bentwheelbob's Avatar
Originally Posted by dreamn69 View Post
Bob,
Not sure if you have heard, but Herb will be at the Nats and will be conducting a suspension seminar. I also have two of his catalogs and can make some copies of some of the technical portions and bring them with me if you would like.
That is too cool. I had not heard that news. Is there a link that talks about Herb being there because I would like to share it with a few people? I looked on the TA Nats website, but it is pretty worthless. They ought to be advertising news like this to draw a bigger turn out.
I would really appreciate it if you could make me copies of the articles. That's a kind offer. Look forward to seeing you in Dayton.
  #882
Old 08-01-2015, 01:00 PM
Alvin's Avatar
Alvin Alvin is offline
Question
I can, just didn't know if there were any legalities involved.
K, so...are the recommended WS6 align specs in your possesion the same, different, or anywhere near the ones as previously posted below?
Castor = 1 to 2 degrees positive
Camber = 1/2 to 1 degree negative
Toe-in = 1/16 inch
  #883
Old 08-01-2015, 10:37 PM
dreamn69 dreamn69 is offline
Here are the excerpts from his book:
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
  #884
Old 08-01-2015, 10:42 PM
Bob,
This was posted by Scott on the TA Nationals FB page:
LAST WEEK TO PREREGISTER FOR NATS!!!!!!!! Remember to get your registration in the mail before this Friday, 7/31 and be a part of the preeminent F-body event in the world! Herb Adams returns this year and will be conducting a suspension and handling seminar. Also attending is author David Barnes. His book, "Blood, Sweat and Gears" tells the story of Herb's racing exploits in the early 70's. Copies of both Mr. Barnes' book and Herb's Chassis book will be available for purchase and we'll have an ample supply of Sharpies on hand so you can get yours autographed. Trans Am Nationals also welcomes back Pontiac historian and Museum Director Tim Dye for a historical presentation guaranteed to feature something new for even the most knowledgeable Firebird enthusiasts. Jim Mattison will also be returning this year to present the state of the Pontiac hobby and answer your question on documenting and authenticating your classic Firebird. Of course, we will be returning to Tipp City for the Saturday night cruise as well as Quaker Steak on Friday night. It's the best weekend of the year for the Firebird faithful so get your registration completed and in the mail TODAY! For those already registered, thank you for your support! Get those 'Bird buttoned up, detailed and ready for show - you won't want to miss ANYTHING at this year's event!
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
  #885
Old 08-02-2015, 07:55 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
So with all this talk, I put my 78 back on the machine yesterday & was able to get 2 degree's positive caster & .7 negative camber. specs are .06 negative toe already, so I kept the machine happy with that one I drove it & It does feel a little tighter off center & returns to straight forward a little better. Nothing real dramatic & there could be some placebo effect in my brain as I paying a lot of attention to it. I might bring the camber closer to neutral & see if it changes anything. I will never be railing the car into the corners at high speed, but I do like the feel of a car that wants to go straight when you let go of the wheel.
One thing I found bothersome is I found my gear box has a tiny bit of play in the sector shaft. Going to look into that this morning. Never noticed it before......
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
  #886
Old 08-02-2015, 08:41 PM
68ragtop's Avatar
OK, Fooled around with my car again for most of the afternoon. initally Set the camber to -1.1 & caster at +2. I went for another ride & I honestly can't notice an improvement with the increase in -camber. I am guessing that it might be useful if I was railing around a closed course track? For fear of wearing the tires (even though I hardly ever drive the car) I decided to get closer to neutral. I ran out of adjustment (no shims in front) on the drivers side & then settled for -.4 camber & 2.0 caster. Being my retentive self, I kept messing with shims until I got both sides identical. Let me tell you that this takes some patience on these cars. Especially with A/C! Newer cars are much easier...... Went for another ride, still handles great. I feel the Caster change is the notable improvement as far as road feel goes.
Turns out my steering box was just fine, the play I was feeling is actually coming from the bottom of the steering column. Not sure if there is a bearing or bushing in there, but its a little loose & I can feel it in the steering wheel just off center, each way.
Didn't mean to take over another section of your thread Bob, but this info seemed to fit this phase of your project & might be useful?
89 Trans am GTA
  #887
Old 08-03-2015, 10:59 PM
Alvin's Avatar
Cool, just watched Velocity "How It's Made" McLaren 650S perform wireless 4-wheel alignment setup and procedure
Makes you want the equipment and the shop!
  #888
Old 08-07-2015, 10:54 PM
I'm getting a Car Show sign made for the Gold Car. The guy has given me two variations and I would appreciate a few votes. There are a few typos (W56 for one) and tweaks that need fixed, but mainly is it car top, or car bottom.
  #889
Old 08-08-2015, 12:20 AM
78 TA KID's Avatar
78 TA KID 78 TA KID is offline
Bob, I like the bottom lay out.
  #890
Old 08-08-2015, 12:50 AM
Gator67's Avatar
Gator67 Gator67 is offline
I like the bottom version.
  #891
Old 08-08-2015, 01:17 AM
3tas4me's Avatar
3tas4me 3tas4me is offline
Bottom
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
  #892
Old 08-08-2015, 01:36 AM
Alvin's Avatar
Thumbs up
Bottom
"Poly Steel Wheels?" Tires perhaps? AND/OR Refinished wheels?
  #893
Old 08-08-2015, 02:41 AM
Formulabruce's Avatar
Bottom, mainly because the car 'cut out" job is hacked bad at the tires on the top one. Looks great though, nice to have if it can save lots of questions.....
"oh is that a "Big BlocK" ? :P
" Long may we DRIVE !"
  #894
Old 08-08-2015, 06:51 AM
RamAir's Avatar
RamAir RamAir is offline
Bottom looks good Bob.
  #895
Old 08-08-2015, 07:03 AM
68ragtop's Avatar
I also vote for the bottom. I had a display made for a car I showed for a couple years that I need to show you. Its almost exactly like your bottom one. Makes me think the same guy worked on it. I'll send you a picture, it would surprise you how similar they are.
89 Trans am GTA
  #896
Old 08-08-2015, 07:08 AM
Thanks, seems unanimous. The typos I caught were the on the wheels and the W56. I also don't really care for the exhaust description.
Took the car to cruis in last night and put about 20 miles on it and man does it drive and run well. It is really a sweet ride and the temps are staying dead on 180 degrees. The only thing that still need some tweaking is the carb at cold idle. The choke isn't coming in like it should and the rpms at cold idle bounce around when the throttle is applied to keep the rev's up while getting it warm. Other than that there isn't much left to do.
Almost time to figure out the next project....
  #897
Old 08-08-2015, 10:53 AM
Alvin's Avatar
Lightbulb
Dropping that 455 HO Pontiac engine mid-ship in your Red NSX perhaps?
  #898
Old 08-08-2015, 05:11 PM
Judge273's Avatar
Judge273 Judge273 is offline
Missed the credit to Dave?
Mike/Illinois
  #899
Old 08-08-2015, 06:14 PM
PB's Avatar
PB PB is offline
Bob, I like the bottom one too. Where are you getting this done? I'd like to make one for my car for MCACN.
Pat Brown
  #900
Old 08-08-2015, 07:06 PM
Bite me. When you give credit to Bill for your Trans Am I will consider it. How is that project coming along?
Thanks Pat, good to hear from you. So will your car be done for MCACN? Just kidding... The guy I am using is Gary Hedlin. Tell him I sent you. His email address is:
[email protected]
I thought about you last weekend when I was buffing out the Gold Car. I hope you are happy with the stuff you bought.
