Old 09-12-2015, 09:40 PM
Bentwheelbob's Avatar
Originally Posted by Norwood View Post
Can I send u my lenses?
Once the season closes I'd be happy to clean them up for you - my pleasure. Only takes about 15 minutes per side. If your serious, send me a PM and I'll get you an address.
Hope all is well with you. I may try to get up to the Mecum show in Schaumburg Oct. 8-10. If you and some of the wild bunch is around we'll have to hook up if I can pull it off.
  #702
Old 09-12-2015, 09:57 PM
Gator67's Avatar
Gator67 Gator67 is offline
Your lens turned out nice. My rate of failure doing this is 20%...use too much muscle and crack them.
  #703
Old 09-12-2015, 10:15 PM
Wet sand up to 5000g and it takes very little pressure with the buffer. I just did one pass with a light cutting pad and the Menzerna to finish them after the sanding.
  #704
Old 09-12-2015, 10:20 PM
njsteve's Avatar
njsteve njsteve is offline
Menzerna? Is that anything like a Mansierre?
https://www.youtube.com/watch?v=YL4Sl6oVuyk
  #705
Old 09-13-2015, 08:44 AM
Norwood's Avatar
Norwood Norwood is offline
Sparky and I normaly take in a day at Mecum.
  #706
Old 09-14-2015, 11:29 AM
Red Goat's Avatar
Red Goat Red Goat is offline
Bob, that lens looks great! Nice work!!!
Cheers,
Tim
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
  #707
Old 09-19-2015, 11:32 AM
Well, today must be my lucky day. I have had an ongoing search on eBay now for over a year looking for bodyside molding for the Black Car, primarily for the door. Bingo, today an NOS piece surfaced and I am now the proud absentee owner. I didn't even look at the price - I just hit Buy It Now. Hopefully it will not be damaged in shipping.
This is the worst piece on the Black Car as at some point a PO shot a screw through the existing molding to lock it in place. Here is the old and new. The old picture was taken during the wet sanding and buff out process.
I now have one door piece, and one front fender piece. I am interested if anyone has a few pieces hoarded away.
  #708
Old 09-19-2015, 01:23 PM
njsteve's Avatar
Did you tell the seller to ship it inside a section of PVC pipe? I think That's how I sent that front piece to you IIRC?
Go Bob Go!
  #709
Old 10-24-2015, 05:47 PM
Ok, so I have thought long and hard about my winter project and have decided to blow up the Black Car and rebuild it. MPD and I started draining the fluids today, and tomorrow we will start pulling the drivetrain and stripping it underhood to the subframe. We are also going to strip the interior and trunk prior to it's journey to the painter. At this time I am not planning to do a full blown rotisserie, but once the car is stripped to metal and the budget is more clear that might change.
I'm pretty excited about this and can't wait to get started. I have been accumulating NOS bodyside molding, but only have 3 of the 6 necessary pieces. Therefore, I plan to have the holes welded over and will leave the molding off until I can collect all 6. I am still undecided on the rear spoiler which was an add on, but I like the way it looks and imagine that I would have added it "back in the day" so it will probably stay.
I do need a at least one part which is the hanger bracket which mounts to front of the oil pan and holds the fuel return/vapor lines from the fuel pump. I would love to have one if anyone can oblige, but a picture of this would also be helpful since I seem to remember thinking that it wouldn't be hard to modify some other hanger to look basically stock. Right know I have a zip tie from NJSteve. I also plan to swap out the metal valance for an ABS valance, but need to know if the ABS valance also requires the center support bracket that Norwood makes.
Thanks in advance for everyone's help. I look forward to helping this section of PY keep from being overrun by the Cream Puff crowd and their girly cars.....
  #710
Old 10-24-2015, 06:22 PM
njsteve's Avatar
To my utter shame, I was never able to find that exact fuel line bracket. It has to have some other application. I know I have seen it before but maybe someone else can ID from memory what is was. (I did use an NOS black cable tie to hold it up there, though - so do I get points for that?)
Bob, the car had NOS quarters and tail panel put on it in back in the 1980s but they did an ugly patchwork of repairs to the inner and outer wheeltubs as no factory pieces were available at the time. Are you going to remove the quarters and redo the inner tubs with the new repro tubs they make now? They actually used the old fashioned brazing method to install the panels, so it might not be as hard to remove the quarters as if they were mig-welded. Unfortunately whoever did the work thought that the rear valance seam to the lower quarters was supposed to be completely filled in. I used a propane torch to melt away a lot of the bulk excess brass in order to expose the original seams.
  #711
Old 10-24-2015, 06:45 PM
eaglesan13 eaglesan13 is online now
Is this the bracket you're looking for?
  #712
Old 10-24-2015, 06:58 PM
Formulabruce's Avatar
This blows my mind!! Get your zip lock bags and markers ready! If bolts could talk! I probably have the bracket for fuel 72. I will look on a couple cars. Good luck. Hope to see it done in 2017 !
" Long may we DRIVE !"
  #713
Old 10-24-2015, 07:29 PM
RamAir's Avatar
RamAir RamAir is offline
I would like to come down and spend a few days with 'the masters' either in tear down or reassembly as an extra hand.
  #714
Old 10-24-2015, 09:46 PM
Thanks for the response.
NJSteve - I love the NOS zip tie...Let's see what the body/restoration guy says once he gets it stripped down, but I'm not planning on removing the quarters to replace inner wheel housings unless it is a real issue. It all seems solid, and I am not looking for perfection so absolute that I won't drive it and end up selling it to a museum owner...Tom Fisher - formally of Muscle Car Alley fame - will be doing the paint and bodywork, and handling the restoration on the core, subframe, and front suspension.
Eaglesan13 - that's the bracket/hanger. Thanks.
Bruce - 2017??? I am planning to have this thing done for driving season next year and the TA NATZ. If you have one of those brackets I would be very appreciative. It would go well with the rest of your hardware holding the car together.
Doug - That would be great, I would love to see you and I know Dave would as well. I'll stay in touch as this progresses. I am hoping to have it stripped down and ready to ship by next Sunday evening, so next weekend will be action packed.
Lastly - I am also looking for NOS inner and outer door sweeps. These would be for a decor trim car.
  #715
Old 10-24-2015, 09:57 PM
Norwood's Avatar
I predict 3 months from start to finish.
  #716
Old 10-24-2015, 10:13 PM
Alvin's Avatar
Alvin Alvin is offline
Cool
Subscribing. This should be another entertaining and teaching thread.
  #717
Old 10-24-2015, 10:19 PM
njsteve's Avatar
Bob, are you sure you need new outer doorsweeps? I could have sworn that when I bought the car it had the wrong ones with the bead on them and I replaced them with NOS correct ones. Or are all my projects just melding together at this point????
  #718
Old 10-25-2015, 06:39 AM
Thanks for the heads up Steve, I'll look at them closely.
I still need to determine whether the Parts Place valance requires Norwoods center support bracket. I'm trying to gather up all the parts and pieces before sending the car south.
  #719
Old 10-25-2015, 07:06 AM
Judge273's Avatar
Judge273 Judge273 is offline
You coming to MCACN? We need to talk about this...
Mike/Illinois
  #720
Old 10-25-2015, 07:35 AM
njsteve's Avatar
Yes it does. The bracket acts as a support and center mounting location under the rad support.
