Old 07-14-2015, 09:25 PM
rdtripn_rte66 rdtripn_rte66 is offline
RV Mirror bracket sold ..... convt top switch im bringing to Norwalk along w other parts....
Robin Triplett
Midwest Director of the Little Indians Club
417-456-9858 cell
63 Lemans convt. Present
1970 350 Firebird motor built to 69 350 HO specs
Aces EFI and Tanks Inc 64 GTO EFI tank (24 gals)
700r4 with 3:23 rear w PB - 69 Camaro rear disc brakes and early S10 front disc brake setup
65 GTO rally guages 67 console ratchet shifter 70 bucket seats 62 GP rear seat w arm rest and center speaker grill (cut down 8")
  #62
Old 07-16-2015, 10:05 AM
chuckolot chuckolot is offline
Default Tensioner
Looking for a new or good condition timing chain tensioner assembly for a 62 4 cylinder
  #63
Old 07-16-2015, 12:26 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
NOS set, 50 shipped.
  #64
Old 07-16-2015, 02:42 PM
Pm sent
  #65
Old 07-18-2015, 02:15 PM
If any one needs something - look back and u will see some parts I have and I will bring to Norwalk if U contact me. Prices Neg just want to help u get urs going......
Robin Triplett
417-456-9858 cell
  #66
Old 07-28-2015, 11:35 AM
Backing up today for Norwalk. Call if u need something. ...
Robin Triplett
417-456-9858 cell
  #67
Old 08-07-2015, 11:32 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 63 Gas Door
Looking for a good or NOS 1963 Lemans gas door. I give one to a chrome plater and he DESTROYED IT...
  #68
Old 09-07-2015, 12:43 AM
Poncho-V's Avatar
Poncho-V Poncho-V is offline
Fuel door trim. Anyone have one of these with the finger grip still attached? I have two just like this.
https://scontent-sjc2-1.xx.fbcdn.net...28399131_o.jpg
  #69
Old 09-07-2015, 10:11 AM
tom s tom s is offline
I need a 63 antenna complete from mast to wire.Want factory no aftermarket.Tom
  #70
Old 09-07-2015, 02:38 PM
moneypit's Avatar
moneypit moneypit is offline
Need working 2spd wiper motor for 62 Lemans.
Let me know what you have, Thanks!
Colt.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
  #71
Old 09-07-2015, 11:08 PM
DeeRock Lemans DeeRock Lemans is offline
Default Fan shroud and 6-blade fan for '62 4-cyl
My '62 Tempest Lemans has a 4-cyl with a stock 4-bbl and it's not just a high-compression engine but a VERY high-compression and needs stronger cooling. If you have any of the 2 mentioned parts, please contact me!
  #72
Old 09-09-2015, 11:40 AM
Default Fan shroud and 6 blade fan
I would contact Dave Johnson - 63Banshee - on forums - out of Dallas. He parts alot of cars.
Good luck - Hes also on the Fb group page for the 63 Pontiac Tempest & Lemans. Robin
Robin Triplett
417-456-9858 cell
  #73
Old 10-23-2015, 02:42 PM
Chiefkey Chiefkey is offline
Default 61-63 Parts Wanted
Hey Guys, Got my front fenders back from the "stripper" and the drivers side fender has some serious damage along the back by the inner re-inforcement bracket. Looking for a decent set of front fenders for a 63, preferably in the S.E. Michigan area, but I'll pay shipping from just about anywhere if need be.
Thanks,
JK
  #74
Old 11-05-2015, 11:32 AM
Default Wtb heater core
That time ouf year, found out my heater core is toast. Looking for a good replacement thanks!
Also 63banshee needs to check his pm box
  #75
Old 11-05-2015, 11:47 AM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
I replaced my heater core a few years ago and used an aftermarket core made by Spectra Premium part #94551. It was available at my nearby auto parts store. I also found another number and I think it is reference to the GM number and it is #399076. They are originally meant for a early 70's chevy van. One of the holes of the heater box will need to be made larger and I used a dremel tool for that.
  #76
Old 11-06-2015, 11:51 AM
Default heater core replacement
how much did you need to grind out? looks like that part is easy enough to find. thinking about putting one in this weekend. also is it correct for the in and out ports to be straight out? the only pics online i can find of a 1962 tempest heater core look like they come out at a 90 degree bend?
  #77
Old 11-06-2015, 12:19 PM
I am not sure how much different the '62 is from the '63 but if you have enough clearance at the hood hinge area then the heater hoses could make that bend without kinking and restricting flow. If not then that core might not work for you. The size of the '63 heater core is 9 1/2" x 6 1/2" x 2 1/2". That size is for the finned portion. If you remove yours you can compare before shopping to confirm that it will fit the '62. I did not need to grind out very much to enlarge the hole, perhaps 1/8". Hope all this helps.
  #78
Old 11-06-2015, 01:59 PM
CONCRETEHART CONCRETEHART is offline
Default heater core
An alternative would be old school radiator shop recoring.
  #79
Old 11-06-2015, 04:57 PM
just looked at the car it, looks pretty easy to pull so i think ill take it out to measure later today. i guess in 62 there was an "old" and "new" style of heating system, the old style had a 90 degree bend for the in and out hoses. looks like i have the new style, which looks simpler with the inlet and outlet straight out the side
ID:	412445   Click image for larger version
ID:	412446   Click image for larger version
  #80
Old 11-07-2015, 02:14 AM
Sanduners's Avatar
*** A little off the topic here - Wanted Parts ***
But,,, I purchased a new heater from Autozone, SPECTRA PREMIUM 94492. I had the local radiator shop change out the top tank, this is the exact same size as original in a 63. Good price too, $42.00.
