Old 11-12-2015, 08:58 PM
grd777 grd777 is offline
Default 1973 interior colour
looking at a car 73 formula n cowl tags states trim is 233 , cant not find what tis is
Old 11-12-2015, 09:09 PM
2manyT/A'S's Avatar
There were some oddball ones that were not listed in the resto guides..
Yours may have come with black interior and RED carpet...
Transamric will chime in...he should know the codes...as I believe he has one...
Eye Candy......garage band?
Go full screen & turn it UP!
Old 11-12-2015, 09:14 PM
johnta1 johnta1 is online now
It's Saddle.
74 is when they went to some weird numbers/combo.
Old 11-12-2015, 09:57 PM
it has red carpet with black seats , but it is a brewtser green car , saddle would make more sense the car is on ebay now for sale
Old 11-12-2015, 10:21 PM
Formulabruce's Avatar
It's Saddle.
and its Standard interior
" Long may we DRIVE !"
Old 11-13-2015, 06:53 AM
thanks for your help how did you find this out
Old 11-13-2015, 07:36 AM
Years and years of experience!
In the Illust & Parts Catalog usually can find the interior codes.
Old 11-13-2015, 11:03 AM
Held for Ransom's Avatar
Or, here http://www.gt-37.org/gallery/main.php?g2_itemId=374
Pick your year.
Get the trim code from your tag.
Drop the first number and add a 1 to the end of the remaining numbers.
Look for the vehicle you're working with and viola.
Old 11-13-2015, 06:46 PM
Pick your year.
o not see 233 anywere here . must be custom
Old 11-13-2015, 07:23 PM
Most sources that have the color codes show 331 for example of Saddle.
Do as Mike said, drop the '1' add '2' to the front of the number. 233 for Saddle
1972 to 1974 (at least) the color codes stamped on the cowl tag were different than what was on build sheets or PHS. (UPC codes?)
I also have some weird codes for 1974 were it seems they may have changed during the year?
1973 Codes:
321 - White (std trim) - 232 on cowl tag
361 - Black (std trim) - 236 on cowl tag
and the saddle.
Old 11-13-2015, 09:51 PM
Here's a page I just made:
1970 - 1974 Firebird Interior Codes
On the 1st 1974 codes, my 74 TA had 209 code on the cowl tag.
(red custom buckets)
Most of the 74 cowl tag pics I looked at had the 2nd set of codes.
But most were later TA's.
Any early 74 cowl tag codes with the different codes than the 2nd set?
Old 11-13-2015, 11:34 PM
Actually it's the reverse of the '1' add '2'.
If the trim tag (Fisher Body) reads ST 73 and TR 233 under it (you would drop the first number (2) and add a number (1) to the end of the trim code) to get 331 which would be the std. Saddle in '73 for Firebird. http://www.gt-37.org/gallery/main.php?g2_itemId=580
John, I don't know where your early '74 numbers came from. All my cars relate to the 2nd set of '74 numbers.
Old 11-16-2015, 05:53 PM
John V. John V. is offline
Two possible explanations that I can think of for the 209 code.
1. Coding error.
Assuming this is not your post and/or not about your '74 TA, here is another guy claiming an odd Trim code on his '74 Formula Data Plate. He also says his has the Custom Red interior.
But he claims the Code on his Data Plate is 208. I wonder if it is a misread? Would be interesting if you can track him down and compare Data Plate notes.
http://www.firebirdnation.com/forums...974-trim-code/
2. Could this possibly be a code to indicate an optional Seat Mix Trim code or Appointment Mix Trim code? I suspect not, but throwing it out there. Here is a link to a good list of the Trim codes and availability of the Seat Mix combos and Appointment Mix combos.
Has at least one error, for the Custom Red it shows code 911. Should show code 901, as it is correctly identified in the "Mix" choices.
http://www.tran-zam.com/1974/1974_Interiors.htm
Elsewhere, I saw a '74 Data Plate that coded the Appointment color even though it was not an optional Appointment Mix trim. The code for the Appointment color was coded by 3 alpha characters, and apparently shorthand for the Appointments color used (BUE in the case I saw, Blue Interior Trim all the way).
Did all '74 Data Plates code the Appointment color this way? That would work for the "standard' Trims and the Appointment Mix trims. But how did they code the Seat Mix trims?
Your 209 code could be an early coding that was abandoned. If so, you'll need to collect Time Built code data along with the codes.
If the other guy misread his Trim code and it is actually 209 same as yours, I'm still guessing it was a mistake.
Maybe a dyslexic relief man (or not very bright) who was trying to code it using the '73 rules. Dropped the 1 at the end, but instead of adding the 2 at the front to get 290, he transposed the 90 to get 09 so when he added the 2 at the front, he got 209.
It would make some sense that the '73 rules were used on very early builds.
In fact, you have to wonder why they changed from the '72/'73 practice of dropping the last digit and adding 2 at the front to dropping the last digit and adding a 5 at the front in '74.
Or why they didn't just use the actual Trim Sales Code rather than encrypt the Trim codes the way they did on the Data Plate in the first place.
But I really doubt they intended to encrypt them by transposing the 2nd and 3rd characters. For that, I have to believe somebody just transposed the nos. by mistake. JMO, I have no other evidence to offer.
Old 11-16-2015, 10:38 PM
Thanks, John.
I took that section out.
It was probably hopeful thinking on my part.
I looked through a ton of 74 tags and only found I think 1 or 2 like mine and they were 209.
Mine has BLK for the appointments.
It was Custom red seats with everything else black.
01A date on tag.
(electric windows/defrost,power locks,AC)
Old 11-17-2015, 05:59 AM
John, I did revisit this and looked thru a couple hard drives. I found I kept a picture of a trim tag w/a 206 on it, 05B car. No other pictures tho. May as well throw them back on there as they were used for sure.
Old 11-17-2015, 01:43 PM
Thanks, Mike.
(and John V)
I put it back in, then started looking at more info I have.
And I found the codes!
Look at it now and see what you think.
The 'appointment' codes are strange, not sure what was actually stamped on cowl tag, but is what was in the chart.
1970-74 Interior Codes
Old 11-17-2015, 02:01 PM
Here's a couple pics showing how to do it.
1972 (1973 basically the same)
1974:
When I saw the '9' for Custom seat thought I might be on the right track.
Not sure it applies in this case but I found the codes.
ID:	413536   Click image for larger version
Old 11-17-2015, 02:14 PM
John, I'm glad you put it back in. When I saw your reply last night, I figured 209 MUST have been related to the Seat Mix option that you described.
Your car has Black Appointments but it ISN'T an Appointment Mix, rather it is a Black Interior (with standard Black Appointments as typical of a regular Black Interior) but with the Red Seats.
The guy in that other old Forum thread thought he had Red Seats. He couldn't figure out exactly what color they were. As it turns out, somebody may have dyed the original White Seats as his 208 Trim Code meant that the car had a Red Interior but with White Seats.
Yours and his had rare "Seat Mix" interiors. Very cool.
As I wondered in my initial post, how would they have coded the Seat Mix option. Now I know!
Old 11-17-2015, 03:34 PM
Transamric's Avatar
John,...tiny, tiny nit to pick from your (appreciated) chart. Morrokide has two 'r's.
Old 11-17-2015, 03:56 PM
1969 Ram Air 1969 Ram Air is offline
If the car was ordered with special order carpet, that item would appear as a separate, no-cost option on the PHS.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
