Old 11-19-2015, 11:33 PM
1978 T/A's Avatar
1978 T/A 1978 T/A is offline
Default Weird issue
So I was changing the dash bulbs on my rally gauges and when I was finished I noticed that I no longer have power when the key is switched to the accessory position.
Gen light does not come on anymore and the aftermarket radio I have wired there does not turn on either. Everything worked fine before. I noticed that afterwards the turn signal lights were finicky, but after messing with the socket they work fine now.
Is the circuit for the gauges somehow a ground for the accessory position?
1969 Verdoro Green GTO
#Matching 400 + .045, 4.21 Ohio Forged Crank, SD 290 KRE heads, Torker II, OF Cam, Etc...
1978 W72 Marty Blue T/A GONE
Old 11-20-2015, 03:11 AM
cuz68's Avatar
cuz68 cuz68 is offline
Wink
You can post this ?, In the 77-81 Firebird & TA tech for more help.
Cuz68
Old 11-20-2015, 03:44 AM
1978 T/A's Avatar
Car I am working on is a 69 GTO. T/A is gone as indicated in my signature.
Old 11-20-2015, 07:54 AM
johnta1 johnta1 is online now
I would ask how you changed the bulbs?
Did you take the gauges out to do it?
Reach up under the dash?
Did you drop the steering column?
The bulb circuit would not have the ground for the key.
But the gauge module should have some ground straps on it.
(but shouldn't affect the key accessory position)
If you dropped the steering column possibly moved the ignition switch out of alignment.
Basically need to know what you actually did to see what was moved?
(or what other things you did to the car)
Old 11-20-2015, 05:18 PM
1978 T/A's Avatar
I reached under the dash and changed them. Only thing that was removed was the ac knee vents.
Old 11-20-2015, 05:46 PM
Is that vent over the steering column?
Old 11-20-2015, 07:15 PM
DOC DOC is offline
If you changed to LED's, They only go in one way. if they don't light, try rotating them 180 degrees and re-install.
Old 11-20-2015, 08:22 PM
1978 T/A's Avatar
Got it figured out!
After I read your post John I crawled under the car and looked at the connector on the column. It had come off the clip so I reattached it and everything works fine now.
Bulbs were replaced with some some philips blue vision w5w bulbs. I had put leds in them and they were too bright for my liking.
