Old 09-24-2007, 04:51 AM
I found the post regarding the lower baffles or filler panel as I called it. Look at post #14 and skip down to #17.
http://forums.maxperformanceinc.com/...ghlight=filler
Old 09-25-2007, 12:25 AM
cuz68's Avatar
cuz68 cuz68 is offline
Wink
The little nibs go on top.
Cuz68
Old 09-25-2007, 01:58 AM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Greg,
I got my new ones from Performance years. I attached the photos of the new and old parts. The longer ones go on top of the radiator and the shorter ones go into the lower brackets. As you can see the new ones are not a great match, but they will fit in the brackets. They will fit in the upper radiator hold down as well, even if they are too short. They are better than the ones I got from OPG - those looked nothing like the old parts and would not fit at all. Maybe they fit a chevy?
Thanks for the link. That description of the "filler panel" sounds like what came out of my car. It is the long rubber strip in the photo. It is attached to the core support between the brackets under the radiator. While I was working on cleaning up the core support I saw that the seals around the frame rails are shot. They sound like what is described in that thread. Time to hunt for those too!
Jon
ID:	105900   Click image for larger version
Old 09-25-2007, 05:41 AM
Jon, thanks for posting the pic of that lower radiator filler/baffle. I've never seen one of those on either of the '68s I have had.
As for the ones that attach to the support and fill the opening around the framerails, I've seen those in the Ames catalog...PY probably has them too. I actually used my originals as a template and cut new ones from roofing paper. That was before I knew they were offered in the Ames catalog.
Old 09-26-2007, 01:21 AM
Roadbuster's Avatar
Found them in Ames' catalog. Looks like I will have to put together an order. They have a lot of the little bits that I am missing. That is part of the fun finding all the little parts for the car!
I need to join the PY journal so I can look up the part numbers. Maybe someone has some NOS radiator isolators.
Jon
Old 09-26-2007, 08:41 AM
Jon, I see you're a relatively new poster. Got any pics of your car? From your avatar it looks like it's painted Carousel Red.
Old 09-26-2007, 09:55 PM
Roadbuster's Avatar
Greg,
My car is not painted Carousel Red, its a bit brighter orange. Here are a couple of pics.
Jon
Edit: I guess I exceeded my limit on attachments. I need to set up a link. Here:
Old 09-27-2007, 06:18 AM
Wow, really sharp car. I'm not usually a big fan of non factory colors on our cars but that really is tastefully done and looks great, especially with those wheels.
Old 09-28-2007, 01:32 AM
Roadbuster's Avatar
Greg,
Thanks for the complements.
I just have to paint the radiator brakets and the core support and then I can install the new radiator, hoses and bits. I figured that the nice shiny new radiator should have a nice clean home. This simple project ended up taking far longer than I anticipated!
Jon
Old 09-29-2007, 02:14 AM
Yeah, I share the same affliction. I went to change a rotten battery tray in the Trans Am and wound up sandblasting and restoring the radiator support and everything associated with removing and replacing it. Then I painted the engine. Took me two or three months to get it back together.
Old 12-20-2015, 10:53 PM
Vol's Avatar
Vol Vol is offline
Opening this up again, as I am not sure by reading through it I have a clear understanding to what is right or wrong. I am assembling as a write this cause I am seeing a lot of issues that previous posters have.
Original 68 core support. Original bottom brackets and isolators. Picture verified as I took it apart. Fan shield is original as are the top isolators.
Fan shield fits like crap with a gap towards the back of core support just ahead of radiator. I have the bolts torqued down considerably. Radiator is 1 ⅝ back from core support at the top. Top isolators can only go in one way from how the nipples align with the holes. I have the larger end of the isolator on the front side of radiator.
I am more concerned with the angle of the radiator as it has the gap stated above and it leans back considerably. See photos.
ID:	416109   Click image for larger version
ID:	416110   Click image for larger version
ID:	416111   Click image for larger version
Old 12-21-2015, 01:22 AM
I just went and looked at mine and there is only about 7/8" between rear edge of the core support and the front edge of the radiator at that point.
The only thing I can think of is that the fan shroud must be different were the rubber isolators are located. I mean, that's what basically sets the space there. Is it an aftermarket piece?
I'll take a photo of mine tomorrow. I don't have a good enough camera to take a decent pic in the present light levels in my garage.
Old 12-21-2015, 05:46 AM
Scott Thelander's Avatar
Default I kinds looks like
possibly the rubbers are in backwards on top
the wide side should go towards the motor and it would stand the radiator up straighter
with the wide side to the front the radiator tilts towards the motor on top..
or the lowers are in wrong...
I do know there are 3 lower brackets at least for the bottom
2 row 3 row 4 core and left and rights... maybe 4 different ...
wish I could help more tonite
Scott
Old 12-21-2015, 04:58 PM
Vol's Avatar
Vol Vol is offline
The top isolator could be swapped, meaning the thicker part pointing towards the the engine vs. toward the radiator. It would gain me ½ inch or so plus the radiator would stand up a bit.
I do have isolators from a 3 core radiator with a tank measurement at 2 ⅝. Those fit that radiator perfectly in the grooves. The 4 core radiator tank is 3 inches. The top mount isolators grooved space is also 3 inches so I think I have those in the right spot. Just made sure not to mix and match sets.
I also checked on a second original fan shield that I have to verify the painted one I have is the same. They are.
Could the 47 year old isolators I am using be swelled? Still looking for answers.
Old 12-21-2015, 08:04 PM
Here are a couple of photos of mine. Now that I can compare your pics to mine, I can see that the rubber isolators are reversed on mine. Thickest part at the rear.. I honestly don't know which way is correct but I don't plan to change mine at this point....
Old 12-21-2015, 08:08 PM
Scott
Yeah, looks like you are correct...
Old 12-26-2015, 04:45 PM
Vol's Avatar
Vol Vol is offline
Ill flip mine around. I would gain ½ to ¾ of an inch by doing so.
Thanks for all the help.
  #38
Old 12-27-2015, 01:05 PM
Vol's Avatar
Vol Vol is offline
One more question about the radiator filler rubber on the bottom of the core support.
I read the post http://forums.maxperformanceinc.com/...ghlight=filler but there were no photos of how it is installed. In this post there are few shots, but I am trying to figure out what type of fastner holds it on? I looked online at AMES and eBay but my search terms did not even find the rubber.
  #39
Old 12-27-2015, 03:36 PM
PurelyGTO68 PurelyGTO68 is offline
The rubber seal is secured with 4 metal retaining clips that are sorta T shaped.
Here are some photos of a core support that I pulled from a LeMans (V8 A/C car) On this example, the seal is also secured on the LH side with the same bolt used to fasten the lower LH radiator mount. Hope these photos help...
Name:	pv 01 lower seal pv.jpg
ID:	416668   Click image for larger version
Name:	pv 02 RH  lower seal.jpg
ID:	416669   Click image for larger version
Name:	pv 03 lower seal clip.jpg
ID:	416670   Click image for larger version
Name:	pv 04 LH lower seal.jpg
  #40
Old 12-27-2015, 10:34 PM
Nice photos... Actually the first time I've ever seen that.
