Old 03-12-2016, 09:15 PM
torqhead's Avatar
torqhead torqhead is offline
Default Harmonic Balancer Removal
Posted this in street too..
How do those of you that have an automatic in the car with a solid flywheel remove the harmonic balancer bolt and re-torque it when you put it back together without have any holes to use on the flywheel. Will grade 8 bolts be strong enough on the front to hold it?
Old 03-12-2016, 11:38 PM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
Install a Pry bar between the heads of 2 flex plate bolts and rotate the balancer CCW until the pry bar handle or shaft is locked in position... Pry bar parallel to the flex plate.
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
Old 03-13-2016, 12:48 AM
torqhead's Avatar
The motor is in the car with trans hooked up so you can't get to the flex plate bolts.
Old 03-13-2016, 12:55 AM
BB70's Avatar
BB70 BB70 is offline
Get a good flywheel holder and rotate- wedge it against the ground, exh pipe.
Old 03-13-2016, 07:34 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
"Indian rope trick"
Back off the rocker arm nuts on one cylinder and feed 2-3' of rope through the spark plug hole. I've done it that way for over 20 years and just did it yesterday using some thick speaker cable.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 03-13-2016, 08:29 AM
aaronman aaronman is online now
http://www.amazon.com/Proform-66792-.../dp/B000CPCA5G
Old 03-13-2016, 08:58 AM
Originally Posted by aaronman View Post
Geez, thinking my former way of jamming the cam lobe against the block valley is safer than that TDC stop.
For a complete engine assembly: indian rope trick on cyl 2, or remove Converter dirt shield and jamb your favorite long steel tool into the converter bolts or in my case the flexplate holes.
Wonder how other brands do this? flex ring Starter teeth?
Old 03-13-2016, 11:03 AM
Joe37 Joe37 is offline
We use a 3/8" thick steel ring bolted to the balancer ( pulley bolts ) with a handle welded to it long enough to reach the frame rail. With four grade 8 bolts, you can torque the balancer to spec's or undo it without getting into the bell housing. It take a lot of force to sheer 4 5/16" grade 8 bolts.
Joe
Old 03-13-2016, 11:46 AM
melemans's Avatar
melemans melemans is offline
+2 Joe37
Old 03-13-2016, 06:37 PM
Originally Posted by melemans View Post
+2 Joe37
I made a tool to do that very thing on the 4 bolt Pontiac balancers, like Joe mentions.
The tool looks something like the pictures below (based on a similar tool shown for tightening the Pinion nut on a rear axle).
You bolt the tool on to the harmonic balancer hub, rest the handle on the frame or on the ground so that the hub does not move, and torque the balancer bolt to 160 ft lbs.
Same deal with removing the bolt. In some cases you need a puller to get the balancer hub off the crank as it is a slight press fit.
I find the tool works a lot better vs the rope in the hole deal, but either will work.
Name:	Balancer holder-1.jpg
ID:	423568   Click image for larger version
Name:	Balancer holder-2.jpg
Old 03-13-2016, 07:57 PM
Gary H's Avatar
Gary H Gary H is offline
Attach two vice gripes side by side on the flywheel or flexplate. When you rotate the engine enough that they touch the bell housing they will keep the engine from rotating.
Old 03-13-2016, 10:07 PM
68greenbird's Avatar
68greenbird 68greenbird is offline
done both the vise grip or pry bar in flex plate pick your favorite .
Old 03-13-2016, 11:41 PM
60man's Avatar
60man 60man is offline
Have resorted to the old starter and breaker bar method too. Place socket on breaker bar and place on crank bolt and rotate around to just below frame rail and secure with rope or tie straps.... Hit starter and breaks bolt loose.
But air impact is safer. ��
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 03-14-2016, 09:23 AM
Originally Posted by Joe37 View Post
We use a 3/8" thick steel ring bolted to the balancer ( pulley bolts ) with a handle welded to it long enough to reach the frame rail. With four grade 8 bolts, you can torque the balancer to spec's or undo it...
Joe
Can you make & sell a bunch? I'll take a square-tubed handle.
