Old 03-28-2016, 10:34 PM
mike leech's Avatar
mike leech mike leech is offline
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #102
Old 03-28-2016, 11:01 PM
john marcella john marcella is offline
Originally Posted by mike leech View Post
I don't know. There's a pushrod on one side of the port, a head bolt on the other side. Valve cover rail above and almost nothing to Seal a valley pan underneath. Never measured them for volume.
The real answer is not big enough. And that's the truth.
Pretty good description. Lol
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #103
Old 03-28-2016, 11:11 PM
60man's Avatar
60man 60man is offline
Whatever it wants
Did it tell you ?
Just curious as I run mine a little tight to help the hammer effect...
at least in my feeble thinking.
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #104
Old 03-28-2016, 11:14 PM
60man's Avatar
Like I said whatever it wants.
Should have read this first.
ECM member.
MANDRA
  #105
Old 03-29-2016, 12:03 AM
bad69bird's Avatar
bad69bird bad69bird is offline
Originally Posted by Half-Inch Stud View Post
Is this Thread sanctioned by the ECM?
Of course it is! Mike is from our Midwest chapter! LOL
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
  #106
Old 03-29-2016, 12:26 PM
dci dci is offline
Mike, This is an awesome thread and will hopefully help shed some light on engines of this caliber for those that are not normally exposed to them. These kinds of threads are very much needed in our small community. As you already know so many guy's don't know what all is involved in making even 800 HP. I know some of the build you cannot or will not expose, but please show as much as you can. Thanks for sharing !!!!
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #107
Old 03-29-2016, 01:16 PM
Stan Weiss's Avatar
So.... Now we take a break to discuss heads. Johns a bad dude. The heads are not what some think or say. The valves have not been moved. In fact the factory installed seats are still in place. The valves are as large as will fit in the stock location. Ti intake...but still a stainless steel exhaust valve. Theres only so much you can do to them .....
Maybe someone has some better graphics software than the freeware I use. The fact that the head is on an angle does not help. I am getting around 2.25-2.3" for the intake and around 1.8" for the exhaust.
Stan
Pontiac Pump Gas List
  #108
Old 03-29-2016, 03:55 PM
mike leech's Avatar
Stan
So quick math will tell you that a 2.3 intake and a 1.8 exhaust will not fit in a stock valve location. This head utilizes a stock valve location.
I really do wish they were that big
EHTTFMF!
  #109
Old 03-29-2016, 03:58 PM
With the 1.8" exhaust, 2.25 would be about as big as can fit.
2.3" would work but the exhaust would probably have to be around 1.7" or less.
The original valve seats may need replacing though for this size, though.
  #110
Old 03-29-2016, 06:18 PM
BB70's Avatar
BB70 BB70 is offline
Very nice chamber work, I think 2.25 x 1.74 . Thanks for the look inside your engine Mike.
John
  #111
Old 03-29-2016, 06:29 PM
mike leech's Avatar
I gotta get busy....i just found out we had hiccup with the dyno. Now we are dynoing Thursday!
EHTTFMF!
  #112
Old 03-29-2016, 08:15 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
EHTTFMF
[email protected]. 3460#s
  #113
Old 03-29-2016, 09:10 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Nice welds also, is that you welding the headers and pan? If it is you are multi talented!
  #114
Old 03-29-2016, 09:13 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by LiL Jack View Post
EHTTFMF
^^^Truth^^^
Go fast, see Elvis!
  #115
Old 03-29-2016, 09:14 PM
mike leech's Avatar
Yes. And all the chassis too. Gotta be when yer poor folk
EHTTFMF!
  #116
Old 03-29-2016, 10:26 PM
seancarole seancarole is offline
WoW you're one bad mamajama each year you push the PONCHO to a new level of Excellence!!! Thank You SR .
  #117
Old 03-30-2016, 12:46 AM
mike leech's Avatar
Thank you. We try.....
EHTTFMF!
  #118
Old 03-30-2016, 08:15 AM
Chris Uratchko Chris Uratchko is offline
Nice effort. Mike is a pretty talented dude. He's built nearly everything in the car himself. Guys like him and Marcella seem to have a drive to go way above and beyond. I wish I had that drive. But, no time for that.
Uratchko Racing Engines
www.ure-racing.com
  #119
Old 03-30-2016, 08:37 AM
mgarblik mgarblik is offline
We had a 2.250" intake and a 1.800" exhaust in our heads with stock valve location. Very close together. So much so that on nitro and at high RPM's due to the large stem to guide clearance required, they hit each other. We reduced the exhaust head diameter and increased the stem diameter to 3/8". Problem solved. Normally aspirated, 2.250/1.80 would work OK even with a 5/16" intake stem, but I wouldn't build a max effort engine with those sizes. I would think a larger intake and slightly smaller exhaust would be a better choice, which is probably what Mike chose. Good luck on the dyno.
  #120
Old 03-30-2016, 08:42 AM
Exhaust valve size is critical in n/a engine as well. Pumping losses and camshaft compromise shows up fast in n/a engine ... can't mask it. Exhaust is equally important as intake in n/a.
www.ure-racing.com
