Old 03-30-2016, 10:08 AM
dci dci is offline
Originally Posted by Chris Uratchko View Post
Exhaust valve size is critical in n/a engine as well. Pumping losses and camshaft compromise shows up fast in n/a engine ... can't mask it. Exhaust is equally important as intake in n/a.
Chris,
Is it the throat diameter and what ratio do you like to see (int/exh) for a 9,000 to 10,000 rpm 500+ cube engine? I know this may be something you don't want to disclose, but need to ask. I'm wanting to know for my heads.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #122
Old 03-30-2016, 12:14 PM
cgeise's Avatar
cgeise cgeise is offline
For some the exhaust seems to be the red headed step child in the head equation I have never believed it and never figured it could hurt by having a good flowing exhaust
  #123
Old 03-30-2016, 02:02 PM
mike leech's Avatar
mike leech mike leech is offline
Nice effort. Mike is a pretty talented dude. He's built nearly everything in the car himself. Guys like him and Marcella seem to have a drive to go way above and beyond. I wish I had that drive. But, no time for that.
Stop it. You're making me blush.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #124
Old 03-30-2016, 02:31 PM
slowbird's Avatar
slowbird slowbird is offline
I know its a balancing act but how much do you give the exhaust valve and take away from the intake? Signs that you've tipped the scales too far one??
  #125
Old 03-30-2016, 05:01 PM
We did only exhaust work, many years ago on the Keen's deal (Valve, porting, stepped headers, collector, etc much like Mike is doing and saw a real 3 tenths with a supercharged engine combination. Had to get the bad stuff out of the engine. Info of what the exhaust work does for Mike will be good info to know.
Tom V
  #126
Old 03-30-2016, 08:58 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Man Chris I'd like to hear a few more bars hummed on this topic. I've always thought cracking the EVO a little sooner fix the issue driving the focus on intake port/valve size.
  #127
Old 03-30-2016, 10:03 PM
mike leech's Avatar
And Alrighty then what do we have left....
Intake manifold. So again this is an area where a lot of guys just don't get it. They want a big hp engine and their uterus falls out when someone quotes them $1500 to port an intake.
NEWSFLASH
$1500 isn't even going to come close to supporting a 1100-1200 hp engine with a single 4 cast intake. Truth is theres a ton of time in this. I'm fortunate in that john and i are friends and he didn't charge me too much extra for me to "help". I have more time in mine than i thought it would take him. And he had a bunch more time in it than me.
You're looking at $4000 maybe more either way cast or sheet. Its what it is.
If you put a $1500 ported victor on my engine I suspect you would watch 150-200 hp disappear.
And no its not all cut into a hundred peices and welded back together......lol.
EHTTFMF!
  #128
Old 03-30-2016, 10:10 PM
mike leech's Avatar
Intake.
EHTTFMF!
  #129
Old 03-30-2016, 10:23 PM
mike leech's Avatar
And while we're at it carburetors.....forget $500 used dominators and new $850-1000 carbs.
Nope we are in the land of $2400-3000 carburetors. Time to put your big boy pants on and step up. These carbs used fetch $14-600. And you gotta have it. Put a 1050 dom on it and wave goodbye to lots of power.
EHTTFMF!
  #130
Old 03-30-2016, 10:45 PM
mike leech's Avatar
On my engine we are running regular t&d shaft set up. 1.75 ratio. Nothing fancy. Or exotic.
EHTTFMF!
  #131
Old 03-30-2016, 10:50 PM
JSPONT's Avatar
JSPONT JSPONT is offline
You must want to puke when something goes wrong, adding up the cost of this thread could put a kid through college!!!!
  #132
Old 03-30-2016, 11:09 PM
mike leech's Avatar
Yes. But the hard costs are a constant. Ie even with a issue you don't replace everything. And this is the do it yourself cheap version. Just dop it off at a well know builder and you will spend "tons" more. Guaranteed.
EHTTFMF!
  #133
Old 03-30-2016, 11:27 PM
Flyin79bird's Avatar
Flyin79bird Flyin79bird is offline
So...need a little extra plenum volume there?
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot
72 LeMans "POS" - Next US beast
  #134
Old 03-31-2016, 01:51 AM
john marcella john marcella is offline
Measured airflow on a flow bench ,on a exhaust port = big fat nothing! Just saying. On the ex side the bench will send you down the wrong path , fast.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #135
Old 03-31-2016, 01:56 AM
Originally Posted by dci View Post
Chris,
Phuck ratios.
John Marcella
[email protected]
ph. 248-259-6696
  #136
Old 03-31-2016, 02:00 AM
When it stops responding also very relevant to cam timing.
John Marcella
[email protected]
ph. 248-259-6696
  #137
Old 03-31-2016, 02:02 AM
1247-1256 mark it down!
John Marcella
[email protected]
ph. 248-259-6696
  #138
Old 03-31-2016, 08:35 AM
slowbird's Avatar
NEWSFLASH
It's interesting the responses you get when you try to sell the $3000 intake for $1000-1500. People seem to focus on the heads and think a port matched intake is all that's needed.
  #139
Old 03-31-2016, 08:56 AM
Chris Uratchko Chris Uratchko is offline
LOL
That doesn't even scratch the surface of bizzaro world in engine building.
Most folks in the maximum effort category are wiling to shell 6-10k on cylinder head castings and rightly so after all the work involved.
But, for the engine guy, who is responsible for making it all happen .... you think he can charge 10k labor? Rarely......... if ever.
Uratchko Racing Engines
www.ure-racing.com
  #140
Old 03-31-2016, 09:35 AM
tpssonic's Avatar
tpssonic tpssonic is offline
Originally Posted by GTO Dan View Post
That is an impressive group (you included). The ability to toss around, discuss and debate ideas with people like that is invaluable. Thanks again for including all of us.
What he said.
