I was in an El Camino when a front one let go. Concrete highway, we vaulted, enough to send us into the median, where it rolled on it's side. Not fun. At least the shaft didn't vault us completely over though, it collapsed. The remains were interesting.
Friend was at the track standing off to the side of the burnout box, rear joint let go in a car heating them, shot a piece of u-joint back and hit him in the knee. Nothing broken, but wow did that thing swell up. I was in a 69 Chevelle, project car, no rear trim around the rear glass, doing around 100 mph on the same highway the El Camino had the incident, rear glass blew out, helicoptered, landed in the median, we went back and got it, it was still intact. Only a small chip in one corner. I was going to use one of those type that slip in under the trans mount, but it made the angles boogered and couldn't use it. .
Were the side windows open on the vehicle that blew out the back window?
I think Mythbusters even did one on vaulting the car. I don't think they got theirs to do it.
What a job figure out new ways to wreck or blow up stuff!
Drive Shaft Safety Loop
This one looks interesting from Ram Air Restorations. No modifictations needed to the car.
You think that can handle it if needed?
www.bowhanger.com 468 poncho powered 66 cutlass 77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html |
The ones that bridge the frame like a cross-member are the best because they are typically stronger and less likely to be twisted out of the mounting location if the driveshaft u-joint does let go. Tom V.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
The RARE loop is what I wanted to do. But the trans mount sits in a pocket of the cross member. Raising it out, plus the thickness of the loop metal puts the trans yoke too close to the tunnel for my liking.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
I have seen people take a spare cross-member to a welding shop and have them weld a tab at the right position on the rear of the cross-member, then cut the RARE piece and adapt it to the modded cross-member so that you have the right hoop height and hoop position on the driveshaft.
The nice thing is that the parts can be easily removed at a later date and you have not drilled holes in your floorboards or welded stuff into the car that screws up the value. Some do not even bother with the RARE part and make a fabricated HOOP and weld that on to the spare crossmember so it is even a better design. Tom V.
Thought I could get a shot of it but it's too dark in the garage and that car is just too damned low to the ground. I'll get it out in the sunlight tomorrow if it doesn't rain. Mine is bolted to the subframe connectors. I think some of the high dollar ones are even already set up for it this way.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
Loop
Finally got under the car today.
Loop
Number two.
#38
This is what I built for my 62.
