Old 05-03-2016, 06:48 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Thanks Craig.
Here's a few pics of the spindles. I could also strip the paint off and use some of that Tectyl 846 that William mentioned.
Mike, any indication which parts he used that stuff on, like the spindles? If so, how's it holding up by now? A.k.a. Cosmoline...
I'm seeing some casting numbers on these and date codes. Casting number looks like 3983992 and looks like F230 - June 23, 1970 (A Tuesday).
This one looks like casting number 3983991 but the date code seems odd. It sort of looks like B27 - just 3 characters as far as I can tell. Not sure what is up with that.
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
  #122
Old 05-03-2016, 07:24 PM
Judge273's Avatar
Judge273 Judge273 is offline
You can see a little flash rust thru the cosmoline....
But, that lug on stud is said to be original.
Chad, What's your thoughts on the 71 Lugs?
Mike/Illinois
  #123
Old 05-03-2016, 08:57 PM
TA455HO's Avatar
1971 Trans Am had two options for lug nuts
399683 - tall cap stainless steel acorn lug nuts
484391 - black center eye lug nuts
The 484391 was a carryover from 1970 so you would typically see these on early build cars, but either is possible. I'd say anything after the strike would probably generally have the acorn style.
  #124
Old 05-04-2016, 07:40 AM
Judge273's Avatar
Do you have any tall SS capped ones?
The ones I was being told were solid chrome type finish?
Shaped like an acorn with a flat top.
Mike/Illinois
  #125
Old 05-04-2016, 10:15 AM
TA455HO's Avatar
The humidity in Memphis must be sick. Lol. If that is an original stainless steel shelled acorn lug it's got some surface rust showing, doesn't it? I do know stainless can rust, but that's wild.
I sold some NOS sets I had on eBay for North of $400 a set. Wish I had a lot more.
You can always tell a box/bag of stainless shelled acorns from solid chrome. As they bump against each other the stainless shelled ones have a very distinct hollow sound.
You are welcome to these for $6 to cover the cost of shipping if you'd like them. They are used and would need a bit of TLC but should be correct as far as I know. Giving Mike S. first dibs on these since he asked....they do not have a flat top to them. If you were close by I'd bring them to you...PM me if you'd like them. I can't do much better on price. Lol
  #126
Old 05-04-2016, 10:20 AM
RamAir's Avatar
RamAir RamAir is offline
Mine are a little different in that they are caps.
  #127
Old 05-04-2016, 10:23 AM
Bentwheelbob's Avatar
I've been using Rust Prevention Magic produced by ECS to prevent rust on bare steel, and I think it is a good product. I'm sure there's others that I haven't tried.
  #128
Old 05-04-2016, 10:33 AM
TA455HO's Avatar
RPM. I saw that advertised by National Parts Depot in an e-mail and thought about it, too. Any pics of treated parts you can share? Feel free to post them here. I think that AMCPacer (?) guy was also talking about it on here.
  #129
Old 05-04-2016, 10:44 AM
TA455HO's Avatar
Originally Posted by RamAir View Post
[IMG]
I'm sure they had a few different vendors that supplied their lug nuts. Even the NOS sets I had varied some from box to box, not all identical.
  #130
Old 05-04-2016, 12:32 PM
Judge273's Avatar
Things flash rust in Memphis before you get a protectant on it....haha
The lugs in question were from Blls car originally and are solid chrome plated. That's why they are rusty. Craig is looking for the ones he has from Bill.
Will post later...
I have seen the ones Chad posted before, and heard of early black center lugs. Never saw these before.
Mike/Illinois
  #131
Old 05-04-2016, 03:39 PM
Transamric's Avatar
To me these look like later Snowflake lug nuts.
The nuts Chad showed are the same that my '72 TA had. Unfortunately both my current '71's had aftermarket nuts in place, even though I bought them way back in the mid '80's.
IIRC, the 399683 capped nuts were used by every GM division except probably Cadillac. They were a royal pain to deal with because tire shops would often over tighten them using air guns, and next time you tried to remove them the right way with a socket the stainless cap would spin on the nut.
  #132
Old 05-04-2016, 04:04 PM
77 Canamman's Avatar
Talking
Originally Posted by TA455HO View Post
Sold new from Householders dealership in Ohio. Mentioned back a couple of pages. Look for my post #67 and read a couple forward from there. Second owner brought the car to WA. I've had it in the garage since 1996 time frame. I believe that was Oakley Householder that chimed in there - his family owned the dealership.
My '77 T/A was also sold new at this dealership.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #133
Old 05-04-2016, 04:40 PM
TA455HO's Avatar
Mike, not casting stones here, but tell me about the rear drums. They look great but I didn't think they used the finned drums until 1973. The smooth drums were used on Firebird, Chevelle, Camaro, etc. and ones I've seen have a casting number of 3993560. Not a big deal, one of those things you don't see much once installed, just was curious what you know about them and maybe the front disks, too. Did you get the date coded NOS disks he mentioned?
  #134
Old 05-04-2016, 04:50 PM
Judge273's Avatar
Chad, The NOS rotors were sold about the same time the nos heat shroud too. Not sure on finned drums as that's a good question.
Mike/Illinois
  #135
Old 05-04-2016, 05:16 PM
SD455DJ SD455DJ is offline
Here's an original '71 rear brake drum...finless.
Dennis
Name:	CJ Axle Code_resized.jpg
  #136
Old 05-04-2016, 05:50 PM
TA455HO's Avatar
That looks like correct style. I would love to zoom in on about the 1 o'clock position and see if that is casting number 3993560. Looks like it probably is.
Edit: I saved off a copy of your picture and zoomed in and rotated it 180 degrees and that does seem to be the casting number all right. Tell me if you disagree.
3993560 right about there ^^
  #137
Old 05-04-2016, 06:01 PM
Judge273's Avatar
I'd say it's clear...part number and tag too. That's documentation!
Mike/Illinois
  #138
Old 05-04-2016, 06:12 PM
Here's a couple media blasted bare metal parts with RPM applied.
  #139
Old 05-05-2016, 07:07 AM
Chad, You are correct, that is the casting number 3993560. Dennis
  #140
Old 05-05-2016, 09:39 AM
Judge273's Avatar
I need those now...
Mike/Illinois
