Old 05-19-2016, 07:48 PM
Check6 Check6 is offline
Default Need the gap spacing for pts. and plugs 66 GTO 389 4 speed
Title says it all. Looking for the gap spacing for pts. and plugs. for a 389 4 speed. Also what's the best plugs?
Thanks,
Fred
Old 05-19-2016, 09:21 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
IIRC points are 19 and plugs are 35. I use A/C Delco R43s in my 67 400 but have thought about trying the E3.51.
Old 05-20-2016, 06:47 AM
Hi fyrffytr1,
Thanks for the info.
Fred
Old 05-20-2016, 09:53 AM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
Per a Chilton's repair manual (anyone remember those)dated 1973, for 1966 GTO 389 breaker gap is .019, the plug gap is .035 (AC44S).
Per the AMA Specifications sheet in my 1966 PHS documentation, breaker gap is .016, and plug gap is .033 - .038, same plug
Old 05-20-2016, 12:03 PM
Mine is Motor's, same year.
I always used adjustable points and set it by dwell reading.
(30º)
Plugs usually .032"-.035"
Old 05-20-2016, 07:08 PM
If your running a lot of timing put the point gap at 16ths or 30 for dwell & the plugs at 32 so your not blowing the spark out when its running advanced.
Old 05-20-2016, 08:18 PM
I ended up using AC 45 S, that what was in the car and that's what the parts book had as the plug. I set the points at .19. I don't have a dwell meter. May get that and the timing checked at my buddies. I'm also installing a new dist. cap and wires. Car starts quickly and runs smooth. Here are a few pics.
Thanks,
Fred
ID:	428793   Click image for larger version
ID:	428794   Click image for larger version
ID:	428795   Click image for larger version
ID:	428796   Click image for larger version
Old 05-20-2016, 09:35 PM
GT182's Avatar
GT182 GT182 is offline
Yep, I have the same one.
Funny thing is, I had given it away just when we moved down here to Delaware in 2006 to a friend with a small auto repair shop. Not so funny is that I bought it back from him after I bought my 66 GTO in 2007.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-18-2016, 12:04 AM
wander wander is offline
points set by dwell meter at 28 degrees.
