Old 06-25-2016, 10:27 AM
Nice numbers! Note made on the cam selection, though I would probably prefer a step up or two. How does that thing idle, like 700 RPM?
  #122
Old 06-25-2016, 10:29 AM
wheneaglesfly wheneaglesfly is offline
Originally Posted by slowbird View Post
Where in Chicago are you from? I haven't seen -30 degrees or 140 degrees here. How does your car run in those conditions?
LaSalle County.
I have started both my 1970-1/2 T/A & 1963 Grand Prix when it was -20F.
Tested & passed .
I live on my farm. Gets much colder than Montgomery in the winter.
Perhaps Hotter too.
I drove to Joliet yesterday 90-100 mph in my 1963 Grand Prix.
70 miles non stop.
No Overdrive.
Turbo 400.
3.23 Posi 9.3 rear.
  #123
Old 06-25-2016, 10:49 AM
gtofreek's Avatar
gtofreek gtofreek is offline
In the video it was idling around 1000-1100 RPM. Didn't try to see how low it would go. Engine needs to make at least 9" of vacuum at idle. Not sure if he could have gone any bigger on cam for this.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #124
Old 06-26-2016, 01:45 PM
gtofreek's Avatar
I was looking at the dyno sheet again, and it made 550 FT. Lbs. or better for a 3500 RPM range. From 2400-5900 rpm. That's a torque monster there. A 500" Caddy engine peaked at 550.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #125
Old 06-26-2016, 01:58 PM
my69brd my69brd is offline
I put the dyno run into a graph so it would be a little easier to visualize
  #126
Old 06-26-2016, 02:24 PM
gtofreek's Avatar
That's a pretty flat torque curve. It's gonna make that 69 Bird actually fly!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
