Old 07-21-2016, 09:00 PM
Norwood's Avatar
Norwood Norwood is offline
Show me some nos outer door handles
  #242
Old 07-21-2016, 09:07 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Originally Posted by njsteve View Post
Here's a trick: If you take the photo with a ruler next to the object, then the eventual user can just enlarge the photo until the ruler matches an actual size ruler.
If Bob hadn't made me change all my photobucket folders to private then anyone could click on it and supersize it. I'm betting that isn't working now for anyone but me....
I'll see what I can do.
P.S. Just kidding Bob...it was a good thing.
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
  #243
Old 07-21-2016, 09:19 PM
TA455HO's Avatar
You mean these, right?
  #244
Old 07-21-2016, 09:22 PM
TA455HO's Avatar
Just kidding. Do you have some early shorty NOS handles?
BTW: Since this is working so well, I do also need one more of these.
916814 2.585 All F LAMP (clear) 2 1970 1972 2-56
  #245
Old 07-21-2016, 09:42 PM
TA455HO's Avatar
I never did buy a pair of the longer newer style, but I did see a few for sale here and there.
Otherwise, I'll have to work with these. My originals. Not terribly pitted, but I think they need to go to the chrome shop. They have a casting number on the back side of each - and which side they go on - which is helpful for me....
9724318 RH
9724319 LH
  #246
Old 07-21-2016, 09:48 PM
Norwood's Avatar
I think the change came in 75. Longer handles used until 75. Short handles are 75-81
  #247
Old 07-21-2016, 10:13 PM
TA455HO's Avatar
Sounds about right. I would have likely bought some if they were the same length.
This old car wasn't in too bad of shape. It was probably fluff-able at one point and then it must have just slipped a little too far, but at least the guy saved nearly everything. These are the original under dash foams for the upper vent duct to cowl flaps. Not NOS, but not too bad for what they are. Not positive of the first part number since I don't find a reference to it yet, just what the assembly manual called out. The LH side foam is the smaller of the two.
3973734 - RH SEAL
477627 9.260 All F exc. A.C SEAL, side vent duct LH 1970 1972 9-21
  #248
Old 07-21-2016, 10:50 PM
TA455HO's Avatar
I did go for some newer strikers, but at least they have the separate collar on the striker neck. I got a third one for that rear door....*chuckle*
20151275 10.569 F, X STRIKER, F&R/D LOCK AR 1976 1981 10-6
These are the screws for the door latch. Notice they have just a small amount of a white putty around the underneath of the head. I'm not going to try to dig up the part number of these. But, they are NOS!!! Funny....
I also bought some door cranks. $15.00 each is marked on them. Probably got them for $13/ A buddy of mine runs Evergreen Muscle Car and I got a number of parts from him, too.
They are the 20322800. People are paying what for these now?
Wiper blades.
  #249
Old 07-22-2016, 12:35 AM
Transamric's Avatar
Originally Posted by TA455HO View Post
Well, I don't have an extra 917399 in a box, but I do have a NOS spare one in one of those funky old cardboard sleeve packages.
I see I need another 917402. Got one of those to trade?
ID:	433237   Click image for larger version
ID:	433238   Click image for larger version
ID:	433239   Click image for larger version
  #250
Old 07-22-2016, 01:34 AM
unruhjonny's Avatar
It's a template. It'd work best if it were somewhat to scale - unless peeps just want to see what it says.
This is exactly where I was going.
I guess a high res picture might suffice, but it would need some way of determining the X & Y to see if it has distorted much...
My day job is all about scale, or maybe I should say crappy plans that are completely not to scale...
1970 Formula 400
  #251
Old 07-22-2016, 08:25 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
On the door cranks 20322800, are these the same cranks for a 1969 GTO? They look the same. If they are in fact used on both A body and F body cars which is easier to find? I bought repos, not overly happy and would like to find NOS ones.
Thanks.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #252
Old 07-22-2016, 10:08 AM
TA455HO's Avatar
No extra 917402. Anything else of interest I can check?
Thanks,
Chad
  #253
Old 07-22-2016, 10:19 AM
TA455HO's Avatar
Thanks.
Hi Chuck. I do believe the same/similar door handles were used across a wide range of cars (Corvette, Chevelle, Camaro, Firebird, GTO, Nova, etc.) but the number 20322800 is a newer part number.
Here's some on eBay that are for sale. See, I'm glad I only paid about $26 for the pair of door handles I have. This is crazy!
http://www.ebay.com/itm/NOS-GM-Clear...JXhsRC&vxp=mtr
At least it is free shipping....
Here's the only other thread where the newer part number was mentioned. Norwood is saying they repop a very correct one for Corvette of the older style?
http://forums.maxperformanceinc.com/...light=20322800
  #254
Old 07-22-2016, 10:42 AM
Norwood's Avatar
I thought this thread spelled it out pretty well. http://forums.maxperformanceinc.com/...t=Window+crank
  #255
Old 07-22-2016, 10:53 AM
TA455HO's Avatar
Oh, good. I had a link to that same info that I pasted in above.
I was comparing my one older 9718137 to the 20322800 and they really are a different shape and the newer one is actually longer, too. If I caliper it from the center of the rings on the chrome part to the center of the rings on the plastic part in a neutral position (not trying to influence the knob from center) I get
3 1/2" on the old one and 3 37/64" on the newer one. Plus the arc is steeper like was mentioned in the other thread. Subtle details.
  #256
Old 07-22-2016, 01:05 PM
TA455HO's Avatar
I was looking at my dual snorkel and realized I didn't have any ThermAC at all. What to do? I thought of Mr. ThermAC himself and sent him a quick note to get his thoughts - what does he do but send me back a link to this little GEM, which I promptly snatched up. I really like the instructions for any of this stuff to add to the archives. Looks like the paperwork is dated 6/70. I'll have to wait a few days for it to arrive, but it should be a welcome addition.
I Thank You, kind sir!
http://www.ebay.com/itm/142051152520...%3AMEBIDX%3AIT
  #257
Old 07-22-2016, 04:42 PM
Held for Ransom's Avatar
The neat thing about this first one is it is a mirror package so you get everything to mount it on a car as well as a large piece of paper to hold on the door as a template of where to cut your door panel and it then has instructions and drawings of how to mount the mirror. The details of the door insides are sort of interesting.
How big is the sheet?
  #258
Old 07-22-2016, 05:07 PM
TA455HO's Avatar
13.5 x 21. My buddy should be back from Cape Cod/R.I. in a couple of weeks and he has a bigger scanner we can probably scan it in two sections and stitch it together.
  #259
Old 07-22-2016, 06:03 PM
Bentwheelbob's Avatar
Take it to a blue print shop to have it scanned. No one is going to have a printer that can print it to scale anyway unless they have a plotter for CAD drawings.
BTW ....I still feel slightly aggrieved by your display of NOS wealth, but that is slightly offset by the unlimited access I have to plotters.
  #260
Old 07-22-2016, 06:48 PM
TA455HO's Avatar
If that doesn't help, I'd bet if you talk to your therapist and really describe how you feel, they might be able to prescribe something.
Last edited by TA455HO; 07-22-2016 at 06:55 PM. Reason: Clarify smart-azzed comment.
