Old 08-24-2016, 10:04 AM
Originally Posted by Jeff Kinsler View Post
So I shouldn't be running 80w 90?
Ha. and not in your TH400 either.
  #42
Old 08-24-2016, 10:23 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Hy guard is close to that lmao
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #43
Old 08-25-2016, 12:12 AM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
A gentleman I work with that has a few big motorcycle wins under his belt in a couple classes running Harley's has tried coating about everything at some point. The only thing he coats now is piston pins. He didn't comment that he found any power, just longevity in that part of the engine build after coating that specific component.
  #44
Old 08-25-2016, 01:44 AM
Anderson Port Development's Avatar
Anderson Port Development Anderson Port Development is offline
... 1000% on the money ...
  #45
Old 08-25-2016, 01:47 AM
Originally Posted by mike leech View Post
I'm running Dewco lube. If I didn't know better I would think it was 10 W 30. Super light weight
... c'mon Mike, you gotta step up to the 0/10 ultra thin weight stuff, and see what really low oil pressure looks like ...
  #46
Old 08-25-2016, 03:12 AM
john marcella john marcella is offline
He's talking about rear gear oil. Not motor oil. And 0/10 is chicken chit. 0 /2 and 0/5 is trying! But not for me.lol
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #47
Old 08-25-2016, 03:56 AM
... I know, I saw his pretty blue stuff laying on top of the heads, at Norwalk , I was just trying to make him laugh ... Lol
  #48
Old 08-25-2016, 08:14 AM
mgarblik mgarblik is offline
Next year a few of the OE's will introduce oil that has 0W/-7 viscosity. Also 0W/-5. That's some thin oil! All about fuel mileage with the OE's. That's a negative viscosity number I am trying to show.
  #49
Old 08-25-2016, 10:31 AM
mike leech's Avatar
mike leech mike leech is offline
Mix 0-5 and 0-20
Running the bearings again they look perfect
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #50
Old 08-25-2016, 10:43 AM
slowbird's Avatar
slowbird slowbird is online now
So my 10-w30 is thick, lol
  #51
Old 08-25-2016, 09:09 PM
Mix 0-5 and 0-20 Running the bearings again they look perfect
Mike, that's super.
  #52
Old 08-25-2016, 10:06 PM
Only as the oil temp comes up. Plenty of localized heat at bearings under big power loads even with cold oil.
Increase oil flow at bearings and it takes away more localized heat.
IMO oil flow at the bearings is more important than oil pressure at the gauge... That said, (but before you jump on me,) consider this...
Why the big pressure needed on a blown nitro or alky motor? The oil gets seriously diluted with fuel... which evaporates to a gas under the heat of the loads imposed on the bearings... gas doesnt lubricate (it would take an enormous amount of gas psi and likely volume to keep a bearing floating on it)... so you flow more oil with greater clearances than you would with undiluted oil(NA app), it takes alot of psi to keep enough diluted oil flowing to try to keep it cool enough to not evaporate the fuel mixed in it.
  #53
Old 08-26-2016, 05:46 PM
LMSRACER's Avatar
LMSRACER LMSRACER is offline
Default Coatings are Evolving.
Mahle Motorsports utilizes a piston skirt coating process that is called Grafal. It's a "Non-Sacrificial" coating that is designed to last 100,000+ miles.
"Hard Anodized" piston coatings have been used by manufacturers for over thirty years and I can personally attest to the fact that they are NOT sacrificial.
Keep in mind that all coatings are not the same and vary from manufacturer to manufacturer. Coatings continue to evolve, so anything that may seem to be fact today, may not be tomorrow.
Having first hand knowledge of NASCAR powertrain coatings, I can say that they are used a lot. Although, Micro-Polishing processes have replaced coatings in some situations.
Have a good one,
Larry S.
http://www.pas4performance.com
Proud to Say, "Made in the USA"
  #54
Old 08-27-2016, 11:39 AM
Tom McQueen Tom McQueen is offline
Were going to use CP hard anodized pistons and will be DLC coating the pins. Thats all.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
  #55
Old 08-28-2016, 02:35 AM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
To tell you the truth if you're using DLC coated pins it says you don't have stuff together on clearance vs pin bending vs bore profile in the piston under cylinder pressure. I hate it because it's expensive but it has it's place. I've had to put two engines into production with steel pistons and DLC coated pins due to running out of time. I'm working projects to remove it!
For limited resource programs/low volume it has it place for solving pin/piston/rod joint issues.
  #56
Old 08-29-2016, 12:53 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Aaron Quinton View Post
... I've had to put two engines into production with steel pistons...
Can I assume from your bio that "we" is GM? I couldn't locate any web info on GM's work with steel pistons; can you point me to such info? Are these diesels?
  #57
Old 08-29-2016, 01:14 AM
cfmcnc cfmcnc is offline
We have pins DLC coated if we plan on more than 18 in vacuum.Not much else gets coated .Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
