#481
You guys' did great! I'm glad my new Hi-Flow unit worked well for Andy & hope you try it. Congrats! Jeff
Carburetor building & modification services Servicing the Pontiac community over 25 years |
#482
ta man, those number are real good.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
#483
Chris, I guess you didn't make it?
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#484
Well another great time with Ernie, nice conditions and finally track prep.
CNC was stuck at work but another Pontiac guy with his nice 71 GTO was there with us in the Poncho camp. He runs a 428 stroked runs 11:70s. Die hard Pontiac guy that is another of my resources. I'm so happy I cant explain. I unloaded the trunk dropped the tire pressure to 18 and that's it. 11:18. No changes from street tune. I actually didn't touch the timing all day. Played with squirter sizes trying to figure out the bog...next couple runs 11:16 ..11:13 then upped the primary jets .for the 10:9 happy happy. Loaded the car up drove home. Its nice to have a guy like TA man to push me....hes so darn positive and a good racer. Thanks for the guidance . We need to get both cars consistant.... |
#485
Getting close to 10's.
What changes netted the 11.16? |
#486
Big thanks to Shaker 455 for a really nice carb.....yes I will call. Theres more in this thing
One change at a time. TA man needs to try it |
#487
What is your combo? |
#488
Nope like Andy said stuck at work
Install 3.42 gears and an overdrive trans.
Mileage would be excellent. Easy 10s with more cam. |
#490
The car gets decent mileage actually with the 3.08's..and settles into a nice purr at 60 to 70mph... I've reached my goals for this year..quite easily and cheap..a new intake with a great port job by Pontiac Derek..and dropping the tailpipes..After watching Andy I have a sense of what I want to do and change on the car...stock appearing sleeper cars have always caught my eye...Andy's car other than the rims looks stock on the outside....mine doesn't fiberglass hood,smoothed door handles..this winter I want to put a stock ta hood back on,start making it more sedate and stock looking..also a few other cosmetic changes...I think Andy and I could blow minds with 2 stock appearing street driven Trans Ams running low 11's and dipping into the 10's
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 09-25-2016 at 11:49 AM. |
#491
Quote]ponhnjon....What is your combo
461 E-Head SD prepped and recently some more enhancements. OF with Harland Sharps1:65s. T-2 SD with Jeffs 4150 unit. TH400 3200 Continental 3:42s. Also to answer 11:16s are a result of carb and intake.....more power everywhere. |
#492
More track time,decent air and Andy running 10's!
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#493
I'll be looking forward to your call.
#494
ta man, What Octane fuel for the 11.17 ET? Not 87 ?!
#495
I run the car normally on 87...going to the track I add 91 to the 3/4 tank mark....It most likely would be ok on 87...I never hear any hint of detonation or pinging romping on it around home..Shortblock has been in service since 2009...so no issues..
#496
Okay so you are probably at 89 octane on the track. Similar for my combo; 87 on street, 100% 89 octane on the track.
Pretty easy to fillerup on 89 in anticipation of the track. |
#497
Cam? |
#498
SDs 315 but with a little work last winter..?.
Old Faithfull. With the rockers( 1:65s really 1:72) I have 641 lift. Docile to drive ,idel at 850ish 14 vacuum. |
#499
Good to see another OF cam combo with times to back it up.
#500
So, will you all get another shot at the track before the weather turns?
