Old 09-30-2016, 05:44 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by 455firebird1969 View Post
So how are you going to attach the front bumper, headlights, bezels & surrounds? That OEM bracket system is heavy...if I had a spare bracket set I'd drill a lot of lightening holes in it. Awesome build, there's nothing better than a fast car with a flat hood.
Current plan is to use the OEM brackets. No plans to drill holes in them to lighten them up.
Anyone making aluminum replacements?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1262
Old 09-30-2016, 05:47 PM
RAIV-Z's Avatar
Originally Posted by moparcolt View Post
You going to do drag week in this thing, just a thought! Awesome event!
Really proves a cars reliability and streetability!
That's the longer team plan, lights, wipers, 2 fuel tanks and the chute mount is setup to double as a trailer hitch.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1263
Old 09-30-2016, 05:55 PM
RAIV-Z's Avatar
Mark does really nice fabrication work with his CNC machine.
The top looks like the same Holley Dominator EFI 105mm top that I installed on my Warrior/Nash dual quad intake (with efi). Mark and I designed an adaptor so that I could run a Accufab Throttle Body. The pics for that deal are over in the Boost Section somewhere.
Don did a great job on the "Split Port" design RA-V heads (No pushrod tube to leak bs) and this very nice intake for those heads. Great Job Don and Mark.
The "ring" was the way to go Ed, a welded top would have moved all over the place and would have needed a lot of extra machining.
Hey Tom,
I believe it's the same top, possibly the same 105mm throttle body. Both Don and Mark do great work, Cheetos to both of them "pun intended".
This one is setup to have the throttle body rearward facing, I believe Mark also has an adapter for forward facing throttle body. Mark can correct me if I'm wrong
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1264
Old 09-30-2016, 07:29 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Can you buy just the top or did you have to purchase the whole intake?
  #1265
Old 10-01-2016, 12:33 PM
cgeise's Avatar
cgeise cgeise is offline
The Injectors I'm using are 235lb Moran Billet Atomizer along with the Holley Dominator ECU.
The injectors operate linearly with pulse width as small as 1.2 milliseconds and opens with the standard 4 amp peak and 1 amp hold ECU drivers.
As its a "STREET CAR" cough cough , it will be interesting to see how those injectors work at low speeds while driving to the Burger King.
  #1266
Old 10-01-2016, 01:01 PM
RAIV-Z's Avatar
I’m interested as well. Mike Moran claimed they would work fine.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1267
Old 10-01-2016, 10:42 PM
JSPONT's Avatar
JSPONT JSPONT is offline
They will, Charlie on the board here runs 235's I'm pretty sure on his 4 cyl.
Drives it like crazy.
  #1268
Old 10-02-2016, 09:47 AM
You can buy each individual part for the Holley EFI stuff.
There are two lids for the intakes: One for the 95mm Throttle body and one for the 105mm throttle body that I am aware of. There may be more.
I have attached a picture showing the different parts you can assemble in different combinations, click on pic for large view.
I modified parts to work with my Warrior Tunnel Ram Intake.
Name:	LS Intake combination parts.jpg
  #1269
Old 11-24-2016, 12:51 AM
RAIV-Z's Avatar
Mark over at Luhn Performance making some progress on the intake. Holley EFI Adapter, O-rings and engraving, should have the finished product soon.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1270
Old 11-24-2016, 11:12 AM
Top on far left bottom is "whatever you want it to be" top?
  #1271
Old 11-24-2016, 12:08 PM
You could make it a Tri-Power Throttle Body Top with EFI, I suppose.
Some would use that top on the base of a Qffy dual quad intake except that the dual quad 4 bbl base is already with-in a few thousands of being a direct bolt on, so wasted money there to mod a blank top.
Some could use the blank top Bruce, when using a Warrior/Nash tunnel ram intake to create a "bottom feed/center feed" type intake design like John Mahovitz did with his race intake. He has excellent air distribution to the runners.
  #1272
Old 12-10-2016, 09:56 AM
RAIV-Z's Avatar
Luhn Performance finished up coating the intake and adding the RaVen logo, now back to finishing up the cold side, pedals and interior paint.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1273
Old 12-10-2016, 10:12 AM
A very nice job on the logo (easy to draw with ink, very difficult to machine in a rounded aluminum manifold top!). Nice work by Luhn Performance.
  #1274
Old 12-24-2016, 12:30 AM
RAIV-Z's Avatar
The Raven exterior just about complete and in color.
ID:	443228   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1275
Old 12-24-2016, 12:41 AM
69FIREBIRD76MM's Avatar
Default Raven
Bad ass 69, Digging the black color.
  #1276
Old 01-30-2017, 08:29 PM
RAIV-Z's Avatar
DCI intake bottom with Luhn Performance mods is ready for mockup.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1277
Old 01-30-2017, 08:34 PM
JSPONT's Avatar
Wow that is pretty!! Very nice!
  #1278
Old 02-11-2017, 07:04 PM
RAIV-Z's Avatar
A few more pics of the Raven in color and the intake in place.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1279
Old 02-11-2017, 07:07 PM
JSPONT's Avatar
Wow that is beautiful!! Great job.
  #1280
Old 02-11-2017, 07:09 PM
dci dci is offline
Ed, I don't know about you, but that makes me all warm and fuzzy inside.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
