Old 10-20-2016, 04:07 PM
carpoor carpoor is offline
Default Hard starting SOB...
Trying to figure out why my father's car is so cold blooded. It literally will not start unless I squirt starter fluid into the carburetor. Once running, it runs great. The engine is a freshly rebuilt 400, rebuilt to stock 72' specs. Carburetor was redone by Ken @ everyday performance. He did the Qjet on my 72' Monte Carlo, it was great right out of the box.
I am going to try to reverify the base timing. But, I am also thinking that the choke could be an issue.
Any suggestions are appreciated. TIA
1972 Chevelle SS 2dr hardtop 454 LS5 4 spd - "Pure Stock"
1969 Chevelle 2dr hardtop L72/M20 - my "retirement" project.
1968 Chevelle 2dr hardtop 6.0/80E - pro tour-ish
1972 Monte Carlo turbo 6.0/TH400
2001 Silverado RCSS LQ4/80E swapped, cam, headers, FBO.
1972 E lCamino SS AFR headed 454/TH400 - the old man's project
Old 10-20-2016, 04:28 PM
probably a choke issue. the choke should be pretty much closed on startup. you'll also need to ensure your accelerator pump is working.
2007 Grand Prix GXP 5.3L
Old 10-20-2016, 04:34 PM
Schurkey Schurkey is offline
WHAT CAR???
1. IS THERE FUEL IN THE FLOAT BOWL WHEN YOU CRANK THE ENGINE? Common for the float bowl to be empty, so the engine has to crank long enough for the fuel pump to supply fuel to the carb before it starts.
2. What is cranking compression?
3. How much voltage at the coil during cranking?
4. Does the choke shut fully?
5. Points ignition? Is the condenser in good condition?
Old 10-20-2016, 04:48 PM
Sirrotica's Avatar
Most likely the choke operation is the problem, It should be completely closed with slight tension on it when completely cold. If not, you'll be pumping the accelerator 10 times to get it to start cold and constantly feathering the gas to keep it running for the first few minutes.
Another problem could be the bowl plugs leaking and emptying the fuel bowl overnight, and having nothing in the fuel bowl upon start up would also necessitate getting fuel/ether into the intake tract. Q Jets are notorious for this problem and removing the carb soon after driving and keeping it level and upright will allow you to lift it up overhead to see if in fact the bowl plugs are leaking fuel. The odd shaped hole between the primaries is where you'll see fuel seeping. If the problem is after a few days of sitting the deathanol laced fuel will evaporate also leaving the float bowl empty.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-20-2016, 06:16 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Yup, leaking well plugs would be my guess..
On carbs with this condition, i like to spin the engine 3 or 4 revolutions before working the pedal. Then pump the pedal several times, then crank some more. This gives the fuel pump a chance to fill the float bowl before setting the choke.
What ever happened to those hi density foam pads that came in the carb kits that would sandwich between the base and body under the bowl?
Guess they went away with the leather accelerator pumps.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 10-20-2016, 06:35 PM
How come when a car has a problem its a SOB
But when the car preforms well, it's a She
Guess i need some automotive gender diversity training.
Old 10-20-2016, 10:41 PM
Or simply fuel evaporation, potentially from excess heat of an over-active exhaust crossover in the intake manifold.
We called 'em the "Tomco Tampon"; NAPA used to sell them individually--although I can't instantly find a part number.
Old 10-21-2016, 06:28 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Those foam pads were a complete POS, and never did anything to help that issue.
We also see a good many of these carburetors leak at the front plugs as well. The only real cure for leaking bottom plugs is to remove them and install screw in plugs coated with Marine Tex or Devcon....IMHO.
Fuel leaves the carburetor in three ways, evaporation, drains back, and at the bottom plugs. At best after a hot shut-down it the bowl will be pretty much dried up in about a week.
Even so the fuel pump should have fuel back in the bowl after a few cranks of the starter. If it takes many cranking cycles and the engine is still hard to start check pump shot and make sure the choke flap is tightly shut, one of these will be the issue......Cliff
Old 10-21-2016, 09:36 AM
Oh, my side hurts while rolling in the floor.
Old 10-21-2016, 12:31 PM
They were made different back in the day. The top side (plug side) had a slick rubber type finish. The foam mashed the slick finish tight against the plugs and actually worked. At least for a little while.
The new stuff is a joke. Not even a good sponge. It's like they shrink when gas(?) or what ever it is gets on them.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 10-21-2016, 02:57 PM
Cliff R's Avatar
Clay, you are correct, and I have had to remove thousands of them with a pocket knife installed from kits decades ago. In not one single instance did any of those foam pads seal up the bottom plugs for very long.
Just about as bad is dabbing JB Weld over them, it gets soft and peels right off with a little help from my knife. Even when it looks like the JB Weld has stuck well, it fails an air pressure leak test 100 percent of the time....FWIW....Cliff
Old 10-21-2016, 03:50 PM
"In not one single instance did any of those foam pads seal up the bottom plugs for very long."
--Anything to get it past that 12/12 warranty
Im well versed in q-jets but i would definitely send that operation out to some one with experience and is set up with the proper tools and equipment.
Old 10-23-2016, 11:15 AM
supercar supercar is offline
I had hard cranking issues with my 66 327 Corvette. My fuel pump went out on a road trip and I replaced it with the correct one it has started on the first turn of the key ever since. Makes me think it was weak at cranking RPMs.
Old 10-23-2016, 01:30 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Cliff, have you ever used the green Loctite made for sealing porosity on those well plugs? Just curious if that is a way to seal the plugs without removing them. I used it on a few Q-jet rebuilds, but never saw them again, so not sure how well it worked. Maybe the fact that I never heard back from them is an indication that it might have worked. I would place a puddle of it on the plugs, and let it sit for a while to seep into any possible leaking spots, then wipe off excess after a 1/2 hour or so.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 10-24-2016, 06:22 AM
On Chevys with fuel issues many times I found fuel pump push rod bent!
Old 10-24-2016, 07:29 AM
Cliff R's Avatar
"Cliff, have you ever used the green Loctite made for sealing porosity on those well plugs?"
No. I've seen a number of attempts to seal bottom plugs, and nothing is going to work permanently aside from removing them and installing screw in plugs coated with Devcon or Marine Tex.
It amazes me to this day how good some of the sealing jobs look, but 100 percent of the time if the plugs are leaking they dabbed on glue fails a leak test with compressed air.
Most leaks that cause running issues and difficult hot restarts are the front plugs, not the rear ones. The rear ones are encased in the lower gasket, where the front plugs leak gas directly into the intake.
Front plugs are also much smaller and very difficult to get the material around them clean enough to hold any type of epoxy anyhow. We drill those plugs out here, and tap the casting for screw in plugs, it is a permanent repair and to date we've never got one back that leaked......Cliff
Old 10-24-2016, 11:23 AM
PontGuy's Avatar
PontGuy PontGuy is offline
My Dad gave me a 78 GP years ago that wouldn't start without being primed. The problem was definitely the fuel pump. The pump worked good enough to get fuel to the carb once the engine was running but it was too weak to pump fuel into the carb when cranking. No gas, no go.
Crank it for 5-10 seconds, then see if you get a pump shot. If not then replace the fuel pump.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 10-25-2016, 02:53 PM
zeebo's Avatar
zeebo zeebo is offline
im gonna say a little bit about what we found with my friend's California sourced chevy nova...ran and drove fine..if it sat more than a couple of days, you could not get it started without pouring gas down the carb. after that, ran fine. well to spare you all the swear words and labor, come to find out it was the rubber fuel lines were dry rotted---not enough to leak; but enough to suck air at the top cracks that the fuel pump couldn't prime. we replaced the rubber lines at the tank and up at the fuel pump. car started every time after that.
Old 10-26-2016, 07:55 AM
Yes, that's a big issue also, fuel pumps suck in air much easier than fuel given the choice!
Old 11-21-2016, 11:13 AM
I am thinking this is the issue, brand new pump - but most likely faulty. I cranked it for about 10-15 seconds last weekend, then got out and loosened the fuel line from pump to carb - hardly any fuel. New pump should be here soon, hoping to update that it's fixed and all is well.
