73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 11-19-2016, 11:33 PM
73SportCoupe 73SportCoupe is offline
Default Non A/C Heater Box Seals
Hi guys. I'm in search of seals for a non A/C box that attaches to the firewall that holds the blower motor. Does anyone know of a company that makes these seals? I've been searching and have not had any luck. Do I just caulk in the box and the fan? Any suggestions would be great.
AJ
Old 11-20-2016, 10:43 AM
cdrookie cdrookie is offline
i'd just caulk it. i made my own AC delete box and used silicone to seal it.
Old 11-23-2016, 10:58 PM
Thanks! That's what I'll probably end up doing.
Old 11-23-2016, 11:08 PM
just be aware the firewall is not a flat surface. The top sealed with just a little bead but the bottom under the blower motor took a big bead.
Old 11-24-2016, 03:26 PM
Grand73Am Grand73Am is offline
Caulking is a good way to seal parts of it. If you wanted to make a seal, you could also use some foam rubber type sealing material that is available in a roll from a hardware store or some auto parts stores.
Steve F.
Old 02-03-2017, 12:25 PM
Thanks Steve! That's a great idea. I'll keep that in mind
