Old 12-08-2016, 10:38 PM
pontiacpetey's Avatar
pontiacpetey pontiacpetey is offline
Default DUI distributor review
Finally got around to installing my DUI distributor after looking at it for a year. Thought I would post a review. My old distributor was from a 78 trans am, worn out and never set up for my car (72 455 lemans) . the distributor is a really nice piece looking at it, went in easily enough. While I did not notice any huge horsepower increase, the car ran smoother and idled much better than ever before. Higher RPM's were where I noticed the most improvement, nice and smooth with no breakup or misfiring. Also it fired right up without all the cussing haha. It is really nice what a properly set up distributor will do. Im not shilling for DUI but the whole experience from ordering it to installing was a big positive, they are a class act.
Regards, Pete.
Many men go fishing all of their lives without knowing that it is not fish they are after. ~Henry David Thoreau
Old 12-08-2016, 10:44 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default DUI
Same here with mine. I have had no
Issues with it and very happy with customer service
You will not be disappointed!!!!
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 12-08-2016, 11:29 PM
Chris65LeMans's Avatar
Very happy with mine, and found some extra power, too.
Old 12-09-2016, 07:46 AM
PDC PDC is offline
Very happy with mine as well. For a build that dies not require an MSD set up, it's hard to beat the DUI.
Old 12-09-2016, 11:13 AM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
What curve weights/plate and springs come in a DUI?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 12-09-2016, 11:53 AM
David Jones's Avatar
They'll set it up to suit your need.
Old 12-09-2016, 12:38 PM
I've got one in my 695Hp IA motor as well as my pump gas motor in the 78-that one I;ve had for 20 years. Dynoed it against and MSD and the exact same.
Old 12-09-2016, 12:45 PM
Oh i was thinking off the shelf Summit stuff. So then you call them for the custom curve deal? Possitive stop too?
Old 12-09-2016, 02:18 PM
goatwgn goatwgn is offline
Thumbs up
Very happy with mine for several years now.
Old 12-09-2016, 08:34 PM
69FIREBIRD76MM's Avatar
Default DUI dist.
No MSD box needed with just a DUI. Dist. Will it be OK with a 500 hp motor?
