#101
Noteworthy that a ported factory intake will support a 600hp, big bore stroker. Did you have a spacer in there to increase plenum volume?
#102
Sorry if it was mentioned, what head flow?
#103
Rich
68 Firebird 400, #16, xe274, street dominator, 850 DP, hooker headers, t400, 3500 stall, 3.73, 295/65 bfg drag radicals... best 13.27 @ 102.8, 1.90 60ft |
#104
No, just a gasket, and Q-jet. It also had an HEI distributor.
#105
301/230'ish at .600".
#106
It won't change the oil pressure at all. The hole is already there. I just lowered it some so it reaches the oil band of the lifter when the lifter is on the base circle. It does not go down far enough for the lifter to expose it at full lift. This engine had 74 lbs. oil pressure when hot. The reason some hydraulic roller lifters are noisy, is because the oil band is too low, and it is not exposed to the oil hole during it's time on the base circle. This is the critical time the lifter needs to refill before it gets hit again by the lobe. After a short time the lifter is empty, and makes a lot of noise. The volume of oil that can squeeze around the lifter and make it's way to the oil band of the lifter, is not enough to refill the lifter if there is not excessive lifter bore to lifter clearance.
#107
Did it support it, or hold it back? I'm thinking what it made probably isn't the best it would do, since you were restrained with using certain parts.
#108
I'm sure with a single plane intake, and a Holley, it would have easily exceeded 600 HP.
#109
I do like the stock style intake and stealth it provides though, but if I were going that route and it were mine, I'd take it one step further and run factory iron heads on it for giggles, or somehow disguise the aluminum pieces. |
#110
Carb is a little small for it as it had 1.5" of vacuum at full throttle. Had 15" of vacuum at 1100 RPM.
#111
I do kind of like the idea behind this engine though. I'd enjoy a mountain motor that looks completely stock on the outside, RA manifolds and all. Even if it did limit the power potential it would be a ball on the street.
#112
GTOfreak
Should this be done for solid lifters with a lower band as well? Just to keep the lifter band loaded with oil. I'm thinking this will help the lifter wheel live longer. Rich
#113
Well, it certainly couldn't hurt, but when you think about the fact that at only 1000 RPM's, the lifter is rising, and lowering 8 1/3 times per second, so it's usually not an issue with solid lifters, but a hydraulic mechanism is another story.
#114
Did Cliff do the carb? Wish you could have tried other induction options...
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#115
The carb was done by owner, with help from Cliffs book, IIRC.
#116
Was it a one of the larger Q-Jet bodies or the 750 CFM version? Great job on a really cool engine build. Sometimes less is more.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
#117
It was an 800 CFM version, according to the owner.
#118
Re-calculated the compression, and it is 10.76:1. The piston has a 14.7 CC dish.
