Old 01-07-2017, 08:35 PM
Donovan Donovan is offline
Noteworthy that a ported factory intake will support a 600hp, big bore stroker. Did you have a spacer in there to increase plenum volume?
  #102
Old 01-07-2017, 09:41 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Sorry if it was mentioned, what head flow?
  #103
Old 01-07-2017, 11:21 PM
68blackbird's Avatar
68blackbird 68blackbird is offline
Originally Posted by gtofreek View Post
Then I ground a groove in the lifter bore to lower the oil hole for hydraulic roller lifters. You can see the line I scribed 1/4" below the oil hole. This is where I grind down to.
What is this going to do? Will it lower your oil pressure? Could the groove be made in the lifter body rather then the block?
Rich
68 Firebird 400, #16, xe274, street dominator, 850 DP, hooker headers, t400, 3500 stall, 3.73, 295/65 bfg drag radicals... best 13.27 @ 102.8, 1.90 60ft
  #104
Old 01-08-2017, 01:54 AM
gtofreek's Avatar
gtofreek gtofreek is offline
No, just a gasket, and Q-jet. It also had an HEI distributor.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #105
gtofreek's Avatar
301/230'ish at .600".
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #106
Old 01-08-2017, 02:00 AM
gtofreek's Avatar
Rich
It won't change the oil pressure at all. The hole is already there. I just lowered it some so it reaches the oil band of the lifter when the lifter is on the base circle. It does not go down far enough for the lifter to expose it at full lift. This engine had 74 lbs. oil pressure when hot. The reason some hydraulic roller lifters are noisy, is because the oil band is too low, and it is not exposed to the oil hole during it's time on the base circle. This is the critical time the lifter needs to refill before it gets hit again by the lobe. After a short time the lifter is empty, and makes a lot of noise. The volume of oil that can squeeze around the lifter and make it's way to the oil band of the lifter, is not enough to refill the lifter if there is not excessive lifter bore to lifter clearance.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #107
Old 01-08-2017, 11:28 AM
Did it support it, or hold it back? I'm thinking what it made probably isn't the best it would do, since you were restrained with using certain parts.
  #108
Old 01-08-2017, 01:36 PM
gtofreek's Avatar
I'm sure with a single plane intake, and a Holley, it would have easily exceeded 600 HP.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #109
Old 01-08-2017, 02:19 PM
Yeah Paul, I have faith in what you and Jeff turn out of that shop. Although 589 HP and that flat torque curve makes a nice street engine, I would bet you guys could easily surpass that with 505 ci, if you weren't restrained with camshaft and intake. I know that's what certain people want, and that kind of "ties your hands" But I'd bet with your experience, even 650hp would be relatively easy and still very streetable.
I do like the stock style intake and stealth it provides though, but if I were going that route and it were mine, I'd take it one step further and run factory iron heads on it for giggles, or somehow disguise the aluminum pieces.
  #110
Old 01-08-2017, 02:25 PM
gtofreek's Avatar
Carb is a little small for it as it had 1.5" of vacuum at full throttle. Had 15" of vacuum at 1100 RPM.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #111
Old 01-08-2017, 02:31 PM
Ooops, I should have said "carb" along with intake and cam. I do kind of like the idea behind this engine though. I'd enjoy a mountain motor that looks completely stock on the outside, RA manifolds and all. Even if it did limit the power potential it would be a ball on the street.
  #112
Old 01-08-2017, 10:10 PM
GTOfreak
Should this be done for solid lifters with a lower band as well? Just to keep the lifter band loaded with oil. I'm thinking this will help the lifter wheel live longer.
Rich
  #113
Old 01-08-2017, 11:58 PM
gtofreek's Avatar
Well, it certainly couldn't hurt, but when you think about the fact that at only 1000 RPM's, the lifter is rising, and lowering 8 1/3 times per second, so it's usually not an issue with solid lifters, but a hydraulic mechanism is another story.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #114
Old 01-09-2017, 12:10 AM
77 TRASHCAN's Avatar
Paul,
Did Cliff do the carb?
Wish you could have tried other induction options...
Shut it off
Shut it off
  #115
Old 01-09-2017, 12:44 AM
gtofreek's Avatar
The carb was done by owner, with help from Cliffs book, IIRC.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #116
Old 01-09-2017, 05:29 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Was it a one of the larger Q-Jet bodies or the 750 CFM version? Great job on a really cool engine build. Sometimes less is more.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #117
Old 01-09-2017, 12:27 PM
gtofreek's Avatar
It was an 800 CFM version, according to the owner.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #118
Old 01-12-2017, 01:45 AM
gtofreek's Avatar
Re-calculated the compression, and it is 10.76:1. The piston has a 14.7 CC dish.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
