Old 05-29-2017, 01:28 PM
Craig Hendrickson Craig Hendrickson is offline
Pontiac performance Author
Default Packard Panther engine installed!
Hey guys:
My current project, a 1956 Packard "Panther", just had it's engine installed on Saturday. The project was not without it's challenges as any restomod custom is wont to have.
The Panther engine was assembled to the flywheel, clutch and Borg-Warner T-10 4-speed transmission the last couple of days and successfully installed.
The crankshaft pilot bushing is a Dorman 690-032. Because of my mismatched parts, I went to one of the old time guys at the local NAPA store who went back to get an old parts book which actually listed parts by dimension and he found a pilot bushing which was what I needed: 1956 Packard crankshaft and 1963 Ford Borg-Warner T-10 4speed. So that problem solved.
Then there was the problem with the clutch throwout bearing. No one ever put a Borg-Warner 1963 Ford 4-speed transmission into a 1956 Packard. the original Packard manual clutch setup is nothing but a "Rube Goldberg machine", so I went the hod rod hydraulic clutch route. The problem was the mix & match parts caused a 0.150in preload instead of a 0.150in clearance between the clutch fingers and the bearing. I used a Speedway Motors BBC 3-finger clutch, Packard flywheel & bellhousing and a B-W T-10 4speed tranny, so the mismatch wasn't that surprising. I had to modify the throwout bearing shaft rear to get the right clearance, but no problem after that.
Here are some pictures of the install. Yes, the engine went in with the custom made (by me) headers:
Yes, that's a big damn engine. The same physical size as a Chrysler 426 Hemi. My GF was watching the install going in and and was scared spitless about it (a Packard engine with tranny weighs 750lbs). To me: no biggie as I've done it hundreds of times. Tilt it back and forth, left and right and it plops right in with a satisfying "THUD". LOL!
Craig Hendrickson, the "H" in H-O Racing Specialties.
http://www.OriginalHO.com
Old 05-29-2017, 01:50 PM
brut4s's Avatar
brut4s brut4s is offline
Looks good! What's your estimate on power?
Old 05-29-2017, 01:53 PM
77 TRASHCAN's Avatar
Headers look good....not bad for a rocket scientist!
Shut it off
Shut it off
Old 05-29-2017, 03:23 PM
Don Keefe's Avatar
Don Keefe Don Keefe is offline
PY VIP
Looks fantastic, Craig! Give me a call when you have a free minute sometime. I lost your number and voicemail on the last cell phone meltdown.
Founding Editor-in-Chief, Poncho Perfection 10/1/15-12/31/24)
Contributing Editor: Collectible Automobile (1999- )
Author:
"Grand Prix: Pontiac's Luxury Performance Car" (4/27/07)
"How to Restore Your Pontiac GTO" (7/15/2012))
"Pontiac Concept and Show Cars, 1939-1980" (3/25/16)
"Pontiac Performance 1960-1974: The Era of the Super Duty, H.O., & Ram Air Drag & Muscle Cars” (10/15/24)
"Leave the gun, take the cannoli."
Old 05-29-2017, 03:53 PM
Computer says 406HP. Not bad for a 60YO 374!
I'm going to take it Westech Dyno Shop near Ken Crocie and strap it to their chassis dyno for some fine tuning. If I get 325 at the tires, I'll be happy.
Old 05-29-2017, 05:19 PM
brut4s's Avatar
Very nice! I can't wait to see it done.
Old 05-29-2017, 06:50 PM
shawn e.'s Avatar
shawn e. shawn e. is offline
My God that is sexy!!!!!!
"Don't let fatigue make a coward of you."
Old 05-29-2017, 07:12 PM
dataway's Avatar
dataway dataway is offline
Yep, that's a beauty.
Old 05-29-2017, 09:37 PM
If you want to see more about this project, go here, especially the "Restomod" part.
http://1956packardpanther.com/Panthe...ect_Index.html
Old 05-29-2017, 09:50 PM
Unless you are really, really brave and have a lot of $$$ don't ever attempt a custom car restomod project like this. Even I, who knows what I am doing and has enough $$$ has been befuddled by something like this. Be forewarned.
Old 05-30-2017, 11:25 AM
importsmasher's Avatar
importsmasher importsmasher is offline
Love it! 1956 is my favorite year Packard.
Importsmasher
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 06-01-2017, 04:43 PM
Here's an addition to the engine install.
For the carburetor linkage and accelerator pedal on Panther, I elected to use parts from the hot rod world. I had several reasons for this:
1) The original Packard accelerator pedal and linkage system is kind of a "Rube Goldberg" series of rods, pivots and levers.
2) I'm not particularly happy with the straight up accelerator pedal used by Packard such as what is in my 55 Pat. The natural position for one's right foot is angled off slightly clockwise, not straight up.
3) The carb linkage for a 55-56 Caribbean is difficult to find and probably would be expensive and require modification to work with the Holley carbs I am using.
The accelerator pedal assembly is an aftermarket replacement for 1970-72 Chevelle (Summit AMD-X409-3470). It consists of the slanted pedal (angled clockwise), hinge, and pull-lever mechanism:
The throttle cable is a replacement for 1968-72 Chevy SB (Summit GMK-4033-233-705):
The throttle linkage for dual quad is set up progressive (rear carb primary for light throttle, Summit MRG-3830G):
