Old 07-09-2017, 08:47 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
Luhn Oil pump.
53 psi @ 7800 RPM. 960 HP.
Bearings look new after teardown
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 07-09-2017, 08:49 PM
GTOGEORGE's Avatar
Originally Posted by grnmnstr View Post
Luhn Oil pump.
Well HELL thats interesting!
GTO George
Old 07-09-2017, 08:56 PM
Hooter's Avatar
Hooter Hooter is offline
I have a Luhn pump also. Consistent 55-57 psi on the dyno from idle to 7,000 rpm.
67 Bonneville ragtop
Old 07-09-2017, 09:47 PM
Allan Runions2's Avatar
Allan Runions2 Allan Runions2 is offline
George I had a problem with my Butler Pro pump and have since (Last year) switched to the Luhn pump. I just recently ran into other problems but it wasnt the pump.
Old 07-09-2017, 10:02 PM
Atated- "I don't normally hang around the race section but what about the Precision pumps?"
I bought one of their 80 lb pumps for my current 505 engine, it makes peak power at 6000 rpm. I've had no issues with it. Street use.
Old information here:
Formulas's Avatar
Formulas Formulas is offline
Anyone ever take a 80 psi. Pump and put the smaller ball bearing in it ? I wonder what the pressure results would be.
Old 07-09-2017, 10:30 PM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
I also run a Luhn pump. Works great, highly recommended. Thanks Rusty
Blown 4cyl's to the front
Old 07-09-2017, 11:31 PM
GTOGUY32 GTOGUY32 is offline
Hi Guys,
I don't often talk on this forum (maybe less than 5 times). Steve C suggested I reply to this thread. I have had 2 Butler Pro Pumps and had issues with both. After doing a take apart study on the pumps, I found that many of the "modifications" either did not exist OR were counter productive to mitigating cavitation or high flow.
After many discussions with David Butler, he agreed with my synopsis. I sent him a comprehensive write up. Butler has contacted their pump supplier and I believe Butler is in discussions with Mark Luhn to start carrying his pumps due to Mark's higher quality pumps that DO include REAL upgrades.
I have nothing but GREAT things to say about Butler's customer service. If you have an issue or questions, give them a call.
I also have GREAT things to say about Mark Luhn, He's one of the nicest guys I have met in this hobby and knows his stuff.
I am running a Luhn Pump now. My oil pressure is about 100 psi at 6500 rpm. I know that sounds high, because it is. After a couple dozen dyno pulls on my 505 IA2, we pulled four main caps and four rod caps to inspect bearings. They were near perfect and new in appearance. SO, if your oil filter can handle the pressure and you don't mind losing a few HP do to the parasitic loss, and a little more stress on your dizzy gear, high oil pressure is not a bad thing for the bearings.
Back to what others have said about 50 or so PSI at very high RPM, I believe it doesn't take much pressure to float the bearings. Don't forget, measuring pressure at the back of the engine is where the pressure source begins. As oil travels down the oil galleries and bleeds out of the bearings, the pressure at the front of the engine will be less. I have some data I collected on the dyno to show this and by how much with my setup.
Here's my engine on the dyno:
https://www.youtube.com/watch?v=ymWvrHM7Z4o
-Dave
Old 07-09-2017, 11:54 PM
GTOGEORGE's Avatar
Well heck that sure sucks about Butler oil pumps, I guess I just wasted $170 and 3 days!
GTO George
Old 07-10-2017, 12:00 AM
George,
The Butler Pump isn't much more than a plain old Melling, based on what I found. It's still a pump that should get the job done, especially in an engine that is not spinning to the moon with a lot of HP. In my opinion, it isn't worth the extra $100+ over a stock Melling. I had oiling issues I was trying to resolve and the Butler pump did not help resolve the issues, but I was able to resolve them by going to the Luhn Pump, plus some other bearing clearance fixes.
Sorry to hear about your issues. I feel your pain.
Dave
Old 07-10-2017, 12:03 AM
GTO George
Good steady flow and no cavitation far more important than pressure. (Most apps...nitro fueled engines have more obstacles to overcome).
The old 10 psi per 1000 rpm "rule" might apply at sub 4000 rpm but if you have very good flow with no sonic waves from cavitation the bearings stay lubed and cool.
Iirc Titan websitehas a good explanation of what cavitation does.
Luhn has done their homework with their pump pickup design and improvements to the Melling pump. IMO if you've been doing ok with stockish internal pump this should be a worthwhile improvement. Next step would be an external pump with a good pickup design like Luhn's. Dry sump being the ultimate.
Old 07-10-2017, 12:20 AM
GTOGEORGE's Avatar
Originally Posted by GTOGUY32 View Post
George,
Dave
I've had no oiling issues just broke my oil pump and shaft and needed to replace them.
GTO George
Old 07-10-2017, 03:16 AM
Dragncar Dragncar is offline
Its not hard to take a Melling and blueprint it yourself. The you have a Butler "Pro" pump.
Whittmore used to take the 80lb SD pumps and cut either 1./2 a coil or 1 1/2 coils out of the pump spring. I gave him a 70lb pump. Played with shims too.
Why cant we have a manufacturer make us a inexpensive gearoter pump like Fords have ? Better design than a spur pump.
Old 07-10-2017, 08:33 AM
Info on cavitation and how it can break pumps and/or shafts can be be found within these links.
Worthwhile reading!
http://www.titanspeed.com/content/pump/pump_techtalk01
http://www.titanspeed.com/content/pump/pump_techtalk02
Old 07-10-2017, 08:36 AM
GTO George
Cavitation is likely the cause of your pump and shaft breakage. See links I just posted.
Old 07-10-2017, 08:43 AM
Luhn's website looks like they are going to do a gerotor pump.
Titan offers a nice one for Pontiac with improved drive etc.. But it takes oil pan mods to use it. OR use their external pump.
Old 07-10-2017, 09:07 AM
GTOGEORGE's Avatar
NO......that's NOT what happened, I had a problem and it's fixed now. This **** isn't rocket science, sometimes STUFF just happens!
The only problem I have is getting 70 psi out of the Butler pump I have.
GTO George
  #38
Old 07-10-2017, 09:24 AM
So...how did you end up with a broken pump and shaft???
  #39
Old 07-10-2017, 09:33 AM
GTOGEORGE's Avatar
I had a problem and its resolved now......but thanks for asking. Like I said STUFF just happens when your racing. The ONLY problem I have is the oil pump I have now........NO other issues.
GTO George
  #40
Old 07-10-2017, 09:44 AM
Shimming the spring should increase the pressure, unless the length of spring/housing isn't letting spring close the ball?
