Old 05-11-2017, 06:33 PM
My ported round port E heads liked 1.8 on the intake and 1.65 HS (1.71 actual) on the exhaust the best.
  #642
Old 05-11-2017, 07:14 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Hi Skip, what happened when you tried more ratio on the exhaust?
Go fast, see Elvis!
  #643
Old 05-12-2017, 10:08 AM
leeklm's Avatar
leeklm leeklm is offline
Originally Posted by 71 T/A View Post
What are specs on OF2?
Dave is not publishing full specs. On the surface, it is the OF with higher lift, and slightly more duration.
Sent from my XT1585 using Tapatalk
  #644
Old 05-18-2017, 03:55 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Originally Posted by ta man View Post
It may be possible..but I'm pretty sure Dave has done enough dyno testing.I trust his judgement when he is the one porting and setting up the heads and supplying the cam.
Do you know what springs he's using? Mine have a polished, smaller diameter spring than the 99893's that have similar tension but are much lighter in weight.
Dave said he's had excellent results so far. I only have 4 dyno pulls on mine but there was no sign of valve float.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #645
Old 05-18-2017, 06:03 PM
ta man ta man is offline
I'm not sure,he did mention lighter retainers and keepers.
  #646
Old 05-18-2017, 08:21 PM
Steve C. Steve C. is offline
Some might be interested...
Exploring Rocker-arm Ratio and Cam-phase Tuning – Project Pure Poncho
http://www.hotrod.com/articles/hppp-...-phase-tuning/
Brings up the subject of less rocker ratio on the exhaust side. Keep in mind here Pontiac factory iron heads are in use. The exhaust-to-intake flow ratio of aftermarket cylinder heads might be a all different ball game.
Old information here:
  #647
Old 05-18-2017, 08:39 PM
Somewhat related, a comment made by someone on another website....
"Some racers would run the 1.65's on the exhaust side only on a single duration cam to add a little extra to the weak side of the exhaust. But with the dual pattern cams, this isn't necessary. When you get in to really nasty stuff, the 1.65's offer an advantage when you have pushed the opening and closing ramps to their design limits. Then you can squeeze a bit more. In reality, even strongly reworked Pontiac heads have flow limits well within the 1.5's range. Also, there's going to be a small percentage of heads with after-market cams that will get by with the lesser ratio but be so close to coil bind on opening, that the larger ratio will cause problems."
Again with aftermarket heads and a higher flowing exhaust port it might be a different ballgame.
  #648
Old 08-01-2017, 10:54 AM
Currently doing final assembly on engine>I should have it installed early next week.
Name:	new engine pic.jpg
ID:	460180   Click image for larger version
Name:	new heads.jpg
  #649
Old 08-01-2017, 12:07 PM
Paul I did not see your question back then-I only bought enough to do the intakes as they are pricey. I did have the 1.65 HS on both intake and exhaust and it picked up with just the 1.8s on the intake.
  #650
Old 08-01-2017, 01:29 PM
hal101's Avatar
hal101 hal101 is offline
good luck sounds like you are dooing great
  #651
Old 08-01-2017, 07:48 PM
Most of my list for today is complete.Rockers,pushrods installed,valley pan trimmed and installed,intake installed.Port match is perfect from SD.Engine is sealed up..the BOP one piece works good.
Name:	new engine 2.jpg
ID:	460213   Click image for larger version
Name:	new engine 3.jpg
  #652
Old 08-01-2017, 08:29 PM
MUSLCAH MUSLCAH is offline
What are we shooting for with the new motor ?
  #653
Old 08-01-2017, 08:46 PM
No leaks or issues is goal one.Long term goal I think 10.60's without touching convertor or gears.Alot has changed from the shortblock to intake all should be positive.
  #654
Old 08-01-2017, 09:57 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Wonder if Dave would advocate using beehive springs?
  #655
Old 08-01-2017, 09:58 PM
ponjohn's Avatar
I predict 10.91 @ 123 off trailer.
  #656
Old 08-01-2017, 10:48 PM
That would work in the heat....I've told Steve C......tens in the Texas Heat....We have that maybe one day a year.
Just depends on traction,its a bit of a game I play..often a marginal track..and all I have is cheap CE 3 way's for shocks.I make the Mickey's work ,good burnout and it usually hooks.
I'd like to see the mph approach 127/128 this year.
  #657
Old 08-02-2017, 08:45 AM
71 T/A 71 T/A is offline
I think 10.78 at 125 and possibly better than that.
  #658
Old 08-02-2017, 09:04 AM
leeklm's Avatar
You should be close. I need to add more weight to keep my boat at 11.5, even in marginal air!
  #659
Old 08-02-2017, 01:00 PM
71 Goatman's Avatar
71 Goatman 71 Goatman is offline
ta man, I noticed you are running a nice cast aluminum valley pan. Just in the process of freshening my 462 with some KRE heads, after seeing yours am thinking of getting one. Do you run a PVC with that valley pan or did you connect it somewhere else?
71 Goatman
Hot Rods & Horsepower.......A diease for which there is no cure.
71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
  #660
Old 08-02-2017, 01:11 PM
AG's Avatar
AG AG is offline
How are you allowed to run sub 11.50 w/o the required safety equipment?
