Old 08-29-2017, 09:26 AM
AG's Avatar
AG AG is offline
Default Oil pump shim size for 70 psi
What shim thickness behind the pressure relief spring in a 60 psi pump is required to get 70 psi?
Old 08-29-2017, 09:49 AM
Measure your compressed lenght of spring now and divide that by your current oil pressure of 60 to 65 lb.
Old 08-29-2017, 10:46 AM
Make a block off plate to bolt where the pump mounts to the block. Drill and tap a hole in the middle of it for a screw in mechanical guage.
Bucket of oil and drill...then you can set the spring tension exactly where you want it.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 08-29-2017, 11:02 AM
Can you post up Steve how you would come up with the compressed length on the spring on his pump?
Old 08-29-2017, 11:19 AM
Oil up the spring port, pack clay into it , screw the cap plug on and then remove the clay and measure it.
Also set a washer in first that fits close and subtract your washer thickness from your clay measurements.
Old 08-29-2017, 11:29 AM
I tried measuring oil pump springs on a valve spring tester. They are so light it was hard to tell any difference.
Old 08-29-2017, 12:00 PM
I've done that same thing Skip , that's why I took to lenght measurements.
I did a chart on the 80 lb pump years ago but can't track it down lately.
Old 08-29-2017, 12:02 PM
More detail on packing this clay inside the pump please.
ps Skip I can put the cover on the spring and compress and screw the cover on the pump
with one hand. Yes a very light spring. And difficult to measure with accuracy on any spring tester unless a very light psi tester.
Old 08-29-2017, 01:07 PM
This not something you could do with a dial/digital caliper?
Correct for how the spring sits on the ball, bore length, then depth (spring rest) in cap nut. Just seems like it would be easy.
Clay
Old 08-29-2017, 01:25 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Why 70lbs. ? Why not 80lbs. or 60lbs. I'm just curious, not trying to solicit any particular response.
Karl
Old 08-29-2017, 01:27 PM
Clay
I took some of those measurements:
a) Edge of regulation Ball to spring nut mounting surface 1.070"
b) Spring free Length 2.300" (My spring was 2.292")
c) Nut mounting surface to pump = .280"
d) Depth of oil spring pocket on the nut = .443"
f) Pump cover height = .625"
So you have all of those different dimensions, all capable of changing during production.
Luhn Performance actually built a 'Oil Pump Dyno' tester that seems to work well and can hit a oil pressure number really close. I believe that they did some actual shim thickness testing and know what a real shim does to the oil pressure.
Might want to call them
Old 08-29-2017, 05:25 PM
Formula8's Avatar
Formula8 Formula8 is offline
Lets not over complicate this. I did a search on this a while ago and the consensus was .060. Some have used up to .100. That said if a .060 produces approximately a 10psi increase using the 60psi spring, a .100 shim is going to produce what? 76 psi or so?
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 08-29-2017, 05:32 PM
Squidward's Avatar
Yup. I did a Melling 60 psi pump, dropped a hardened 1/16 thick washer (.06-ish) in the spring hole, and called it good. I did this for both of my current engines. I can't remember what the hole diameter was, tho. But use whatever is large enough to fit without getting stuck.
Old 08-30-2017, 12:25 AM
aceaceca's Avatar
aceaceca aceaceca is offline
Well, I once used a 1/4 nut with the peaks rounded off on a 350 Chevy. It blew the filter up and made a nice mess of things.
Old 08-30-2017, 03:01 AM
CROCIE JR's Avatar
CROCIE JR CROCIE JR is offline
.060 is worth 15lbs on a small journal with .0023" on the mains and .0028" on the rods and VR1 30wt. I think I used a AN washer.
Old 08-30-2017, 03:03 AM
CROCIE JR's Avatar
Thats with a .034" lube hole in the front and back.
Old 08-30-2017, 06:11 AM
AG's Avatar
AG AG is offline
Thanks all for the recommendations, looks like a 0.060" shim.
Old 08-30-2017, 07:15 AM
Don't forget about the .034" lube holes in his engine.
Old 08-30-2017, 07:41 AM
RA462's Avatar
RA462 RA462 is offline
I use a 5/16 lock washer that I flatten out. Usually gives me about 70 psi in a 60 pound pump. You might have to grind a slight amount off the OD of the washer to get it to fit inside the spring cap.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 08-30-2017, 07:50 AM
AG's Avatar
AG AG is offline
I always use one.
