Old 09-07-2017, 12:20 PM
eaglesan13 eaglesan13 is online now
Cool car, sold new at Ted Stevens Pontiac in Los Gatos. I used to work at his Honda dealership right around the corner, and I've already got the plate frame hanging in the garage...
Appears to be a great project car for someone:
http://www.ebay.com/itm/1972-Pontiac...JZsI3a&vxp=mtr
  #3002
Old 09-09-2017, 11:27 AM
starlightblack's Avatar
starlightblack starlightblack is offline
yum yum
http://www.ebay.com/itm/292243119119?rmvSB=true
  #3003
Old 09-09-2017, 04:09 PM
I'm high bidder...at the moment...we will see.
  #3004
Old 09-09-2017, 05:00 PM
Judge273's Avatar
Judge273 Judge273 is offline
Like the no console 4 speed look..
Sent from my iPad using Tapatalk
Mike/Illinois
  #3005
Old 09-09-2017, 05:08 PM
Agreed, I always liked that look too.
  #3006
Old 09-09-2017, 09:36 PM
Chickenhawk Chickenhawk is offline
Originally Posted by Transamric View Post
Hurricane Harvey victim??
Notice early correct type wheels.
Nope not a harvey victim but a victim nonetheless.
That car is mine it's victim of 30 plus years out in a North Carolina
Pasture.
Wheels are correct coded mi0 7-28 kn
  #3007
Old 09-10-2017, 03:13 PM
njsteve's Avatar
njsteve njsteve is offline
Originally Posted by starlightblack View Post
That's a great car. Even has its original unitized distributor still in place. (Probably the reason it was parked - they were notoriously undependable). This is a great basis for a restoration. All the born-with parts are there except for the air cleaner base. It also has its 1972 front fenders intact - something you never see!
I got a chuckle out of seeing the Accel Supercoil bolted to the firewall on a car with a unitized ignition. The guy probably bought that coil, bolted it up, and then went to hook up the main coil wire to the dist cap and discovered there was no place on the top of the distributor to plug it into!
Should only take around 100 grand to get it to perfect shape. ;-)
  #3008
Old 09-10-2017, 04:01 PM
necdb3's Avatar
necdb3 necdb3 is offline
My original formula 455 had initized ign, I drove that car over 50k miles before the pick up went bad. Replaced it and it started right up. The only bad thing about them was if you had a problem, parts were harder to get. The were actually very reliable, they just had the stigma about them because nobody knew what to do if something failed, so they called them troublesome.
  #3009
Old 09-10-2017, 07:24 PM
njsteve's Avatar
I agree. Because the parts are just about nonexistent and very expensive when you can find them, they are very troublesome indeed.
  #3010
Old 09-11-2017, 09:27 PM
The auction's over, did you win it?
  #3011
Old 09-11-2017, 10:02 PM
Nope, I wasn't going past 20K, that was my bid. If it were lucy blue I would have gone much higher though.
  #3012
Old 09-12-2017, 08:43 AM
blue71ta's Avatar
blue71ta blue71ta is offline
Rough '71 T/A:
http://www.ebay.com/itm/1971-Pontiac...BZtbrs&vxp=mtr
  #3013
Old 09-20-2017, 12:14 AM
2manyT/A'S's Avatar
Just needs......everything.
Eye Candy......garage band?
Go full screen & turn it UP!
  #3014
Old 10-04-2017, 02:05 PM
2manyT/A'S's Avatar
Default 72 stick on ebay......
Decent car......lots of 70's mods.....
Pretty optimistic on the price, I think....
http://www.ebay.com/itm/182806330452?ul_noapp=true
  #3015
Old 10-04-2017, 02:29 PM
johnta1 johnta1 is online now
That buildsheet and cowl tag are very interesting.
Cool looking TA.
  #3016
Old 10-06-2017, 06:32 AM
Judge273's Avatar
John,
What do you see that's interesting?
Mike/Illinois
  #3017
Old 10-06-2017, 06:59 AM
Body number?
  #3018
Old 10-07-2017, 01:57 PM
Held for Ransom's Avatar
Actually, it looks like a body that was pulled off the line then placed back in a few days later. Referencing the IDENT 180381 from build sheet. New body number is too big (7 digits, not 6).
  #3019
Old 10-07-2017, 03:01 PM
Guess not that unusual.
I found at least 3 other 72 Bird build sheets with a body number marked out and another one put in.
But they were all on the same 'day'?
Box 10 had - 21 01-09
Possibly the person inputting the data was a little off that day?
They had different IDENT numbers, so it may be a 'work ticket' type thing?
(at my old work we called them A.I.T.'s for Additional Instructions To)
  #3020
Old 10-07-2017, 03:33 PM
Transamric's Avatar
We know that there were a few notable changes to the '72 model year Firebirds that were to take place on and after January 1st. Most if not all were federally mandated safety improvements. It appears Pontiac wanted to (or needed to) come up with a way to identify the previous standards body shells from the bodys which incorporated the updated features. The way this was done was by switching from the old 6 digit Body Number (which was up to at least 177xxx by the end of Dec. '71) to a new 7 digit series which began with '21'.
I have found no 21xxxxx Body Numbers dated before 01A and only a handful of 01A bodys which did carry over the old 17xxxx numbers. Our example here appears to be a body that had been scheduled to be built the last week of December but for whatever reason, was held over in to January.
It'd be interesting to know some of the details on this TA to see whether it was assembled with all later changed parts or a mix of early and late. The seat belts/shoulder harnesses are one quick way to ID late from early.
Have we ever composed a list if all the changes which were scheduled to take place on or after January 1st?
