Old 11-06-2017, 09:39 AM
MUSLCAH MUSLCAH is offline
We just had a radio installed in my sons 64 GP....the radio is in the trunk....and you run it with your Smaaht Phone.....has hands free blue tooth ....a little mic near the rear view mirror....play list....all kinds of things...Slick set up.
  #62
Old 11-06-2017, 04:07 PM
unruhjonny's Avatar
Originally Posted by 70TA-RAIII View Post
Thanks! The car will stay non-console just like it was built.
After thinking it thru and listening to the various opinions here, pretty much everything on the car will stay as it's supposed to be.
I'll probably put in a different radio (the original doesn't work anyway) but only something that bolts in with no cutting or modification.
John
Yay!!
I am posting this incase you don't already know it;
1) The AM pushbutton radio (as far as I can recall) is the same unit right up to 1977 - and is the easiest one to get.
2) a Pontiac enthusiast has created a device which makes worrying about upgrading radios almost pointless;
"Redi-Rad" https://redirad.com/
/\ I plan on buying one.
EDIT:
a) As far as I am aware, the AM radio face always has a 'script' style "Delco".
b) Radio came in single speaker output or dual speaker output;
As far as I know all radios which went through an 8-track player used a single output, and the tape playe split the output into two channels.
c) The AM/FM had two distinct looks; the early ones had a 'script' font for the "Delco" logo whereas the latter ones had "Delco" on a little rectangular 'box'.
I hope this helps!
1970 Formula 400
  #63
Old 11-06-2017, 04:51 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The 8-track player was available with mono or stereo radios. There are two different wiring harnesses depending on the radio option. With the single-channel radio the front and rear speaker signals are passed through the 8-track unit and controlled by the balance knob on it. With a stereo radio the balance is controlled by the knob on either the radio or 8-track depending on what is being used at the time.
  #64
Old 11-06-2017, 10:31 PM
70TA-RAIII 70TA-RAIII is offline
Thanks for all of the radio tips! I did not know about the redirad place. I like wiring so all of the wiring info is great too.
John
  #65
Old 11-07-2017, 04:21 PM
unruhjonny's Avatar
thanks for the correction Dennis(?)
1970 Formula 400
  #66
Old 11-07-2017, 08:43 PM
starlightblack's Avatar
starlightblack starlightblack is offline
Originally Posted by azbirds View Post
My theory on the smaller bars. The Birds were built along side the camaro and from what I've heard the workers didn't care to much for building the Birds. They didn't want the T/A's running circles around the lowly camaro so they put smaller bars in trying to level the playing field.
Nope.
  #67
Old 11-08-2017, 06:24 PM
FunctionalShaker FunctionalShaker is offline
I noticed the part number stamped on your front shock is 3192732, but the part number is said to be 3192132. Can anyone clarify? The "7" number does not show up on a search.
  #68
Old 11-08-2017, 06:53 PM
Judge273's Avatar
Judge273 Judge273 is offline
That 7 you refer to looks awfully straight like a 1 to me? Lighting?
Mike/Illinois
  #69
Old 11-09-2017, 07:46 AM
Norwood's Avatar
Norwood Norwood is online now
I would certainly say it’s a 1
  #70
Old 11-09-2017, 01:31 PM
Maybe it's rust and shadow, but it looks like it curves to the right at the top of the vertical. Needs to be cleaned.
  #71
Old 11-11-2017, 01:06 PM
It may not come across great in a picture but it's definitely a 1 and not a 7.
I tried to use a piece of chalk to help highlight it, but I couldn't get the 1 to hold the chalk.
Here's a slightly different view:
And here's the other front shock. Unfortunately the 1 is right at the seam of the shock tube, so not a great picture either, but I think you can tell it's a 1.
John
  #72
Old 11-11-2017, 01:10 PM
Norwood's Avatar
I’ll take your word for it.
  #73
Old 11-11-2017, 06:17 PM
That's good, I mean the part number calls for a one so... Thanks for verifying.
