Old 08-24-2017, 10:28 PM
64speed's Avatar
64speed 64speed is offline
Default Headers vs ram air manifolds
I am trying to put my engine combo together and one variable is exhaust. Are the reproduced ram air manifolds from pypes round port or d port? Does anyone know of an exhaust shop anywhere between Atlanta and Charlotte that can mandrel bend exhaust?
Old 08-24-2017, 11:11 PM
tom s tom s is offline
Have you checked with the Pipes system?Tom
Old 08-25-2017, 12:40 AM
ponyakr's Avatar
ponyakr ponyakr is offline
"...Are the reproduced ram air manifolds from pypes round port or d port?..."
D-port.
https://www.summitracing.com/parts/p...caAiXhEALw_wcB
R.A.R.E makes the big outlet round port manifolds.
http://www.ramairrestoration.com/rm-...oversized.html
Old 08-25-2017, 10:09 AM
Ponyakr touched on it. You can get the big outlet D ports and round ports as well as stock outlet D port and round port. Some of these I've seen somewhere even offer a porting or "clean up" service. Might have been R.A.R.E.
Old 12-19-2017, 12:46 AM
lust4speed's Avatar
No reason for a shop to mandrel bend pipes in-house. The good shops in our area carry a large quantity of mandrel bent tubing pieces in all the necessary angles, and then simply cut and paste a custom system together.
Mick Batson
Old 12-23-2017, 01:58 PM
Exotic Exhaust
7 Ritch Drive
Hiram, GA
770-943-2153
Old information here:
Old 12-23-2017, 02:09 PM
Yes I do that here occasionally when I have an unusual swap where mandrel down pipes aren't made. The mandrel "J" bends aren't expensive to buy, then just cut-turn-angle-weld how needed.
