Old 12-23-2017, 09:32 AM
hal101's Avatar
hal101 hal101 is offline
Default how big of a tire can i fit on the front
i have a 80 ta with 3" pipes and mufflers so i do not have much ground clearance
standard tire is 225/70/15 28.4" tall
on the back i put 235/75/15 28.88 and they fit nice and raised the back .75"
on the front i would like to do the same but not sure if they will fit
so i am asking what is the largest tire anyone has put on the front of a 80 ta ?
Old 12-23-2017, 03:44 PM
77 TRASHCAN's Avatar
I have run several sets (4) of 235/70R15's on my 77. There is a very slight rub at the very edge of the tread, when the wheels are turned to either direction all the way. I'd think that a 235/75R15 being a taller tire would rub worse. I've heard of folks using 255/60R-15's on th front with no issues...
Shut it off
Shut it off
Old 12-23-2017, 04:30 PM
hal101's Avatar
the 235/60/15 is 26.10"
and the 255/60/15 is 27.05"
both shorter than the standard 225/70/15 27..40 so they wont help me gain any ground clearance
but i thank you for your response
Old 12-23-2017, 04:33 PM
hal101's Avatar
sorry that should be 225/70/15 is 27.4"
Old 12-23-2017, 05:02 PM
The 235/70R-15 is taller than the 225. I used the 235/70 tire not the 235/60...
Shut it off
Shut it off
Old 12-23-2017, 06:49 PM
T/A addict T/A addict is offline
Personally.... I have 255/60/15 on all 4 corners or my TATA and on my other '79 I have 275/60/15 on the back and 255/60/15 on the front.
No issues at all.
Old 12-23-2017, 08:28 PM
hal101's Avatar
yes you are right 235/70/15 is 27.95"
that is a good 1/2" taller and you say fit ok just a little rub turned all the way
well that might be the one for me
thank you again
Old 12-23-2017, 08:34 PM
hal101's Avatar
No issues at all.
the 255/60/15 is 27.05 thats .4" shorter than the 225/70/15 so it wont help me get any more ground clearance
but thank you for your reply
Old 12-23-2017, 09:06 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
I got a 245-60-15 on the front of my 71, and it clears everything fine.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 12-23-2017, 09:31 PM
Grand73Am Grand73Am is offline
245-60-15 won't help him. They're only about 26.6" tall. He wants tall tires, closer to 28".
Steve F.
Old 12-24-2017, 08:31 AM
hal101's Avatar
thank you Grand73Am
