Old 01-18-2018, 02:49 AM
cspecken cspecken is offline
Default 1964 Sedan / Post Car Trim Installation Steps
I am trying to determine if I should put the door and rear 1/4 glass aluminum trim on before the installation of the glass or after?
Also does the order impact the installation of the weather strip?
Thank you, Chris
Old 01-18-2018, 11:52 AM
Dick Boneske's Avatar
I'd put it on before glass installation. It does not interfere with glass installation. That's what I did with my '64 Post. Glass installation and adjustment is a challenge, but with patience and a few days, you'll get it right.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-18-2018, 12:00 PM
Thank you for the information. I will hold off until my glass installer completes his job. Lucky for me he is a relative of mine who has 40+ years of installing glass and has seen his share of 'old cars'. One of the best in my area for this type of work.
Chris
Old 01-18-2018, 12:38 PM
The amazing thing to me is that the people on the assy. line in 1964 had about 15 seconds to install & align the windows. They would still be laughing at me if they saw how I spent DAYS getting these installed and working right. It always amazes me how many people do not bother to get the windows adjusted correctly after they spend so much on bodywork, etc. It's especially obvious on hardtops.
BONESTOCK GOATS
Old 02-10-2018, 05:16 PM
Does anyone have any tips on getting the B Pillar (1/4 Rear Window) vertical trim to attach? Having a lot of difficulties on the center clip catching properly on the factor clip. I have the 3 clips in the recessed area on the B Pillar.
Old 02-12-2018, 05:58 PM
michaelroy's Avatar
michaelroy michaelroy is offline
Default verticle trim pc.
I'm pretty sure it just snaps on. No clips needed.
There is a video on You Tube show step by step install on either a 64 or 65.
Old 02-12-2018, 11:00 PM
I have watched the video, he does some explanation regarding the trim but does not show the finished product. Also there are clips as mentioned in the video. I have all of them in place but am finding it a challenge to get the middle clip to go into place.
Thank you
Old 02-14-2018, 05:14 PM
michaelroy's Avatar
Default trim
Not sure what you mean middle clip. Are you speaking of the verticle pieces?
I'll check my pictures and see if I have something that will help.
Old 02-14-2018, 09:03 PM
64speed's Avatar
64speed 64speed is offline
I need the drivers side rear top quarter piece if anyone has a spare the po pop riveted mine on
