Old 08-22-2022, 08:09 PM
64speed's Avatar
64speed 64speed is offline
What are the absolute best pushrods I can get
Old 08-22-2022, 08:27 PM
grivera's Avatar
grivera grivera is offline
Wish I could answer that but it being said, What’s wrong with the brand of pushrods you have now? I’m sure you know, this is unlikely to blame on the pushrods.
Will Rivera
Old 08-22-2022, 08:54 PM
64speed's Avatar
Well I’m getting 16 pushrods cause I don’t want to replace just two. Just wondering
Old 08-24-2022, 11:55 AM
NeighborsComplaint's Avatar
Wait and see what your builder finds.
If the pushrods simply came out, your rocker arms were misadjusted (loose) and turned or rocked enough to allow the pushrods to slip out. That ticking you heard may have been loose rockers.
If the pushrods are bent, then you had mechanical interference at play. Valves may have bounced and kissed the piston top or your rocker ratio and pushrod pocket offset may have caused your retainer to hit the guides. Things like valve spring coil bind need to be rechecked and ruled out but typically, you will also have a broken valve spring from coil bind.
Triple Black 1971 GTO
Old 08-24-2022, 02:18 PM
ZeGermanHam's Avatar
+1 to this.
1998 BMW 328is (track rat)
Old 08-22-2022, 09:02 PM
grivera's Avatar
Definitely understand that as different lifters will likely require a different length pushrod. Do you have the build sheet for your engine? May say the brand and wall thickness of the ones you have now.
Will Rivera
Old 08-22-2022, 09:34 PM
64speed's Avatar
Wayne has it. I’m hoping this goes smoothly and I can be back on the road in about 3 months. Will definitely be getting and MSD box with rev limiter
Old 08-23-2022, 10:09 AM
When you get the rockers off, take a pic of the tops/tips of the valves, can see if the pushrod length was a factor. Might as well take a pic of the bottom of those rockers on #2 as well. Or a few of them.
I would say the most likely cause is retainer clearance, but if that's the problem, it's going to be a builder issue, and he may just do the same thing over again. (since he didn't check/catch it the first time).
Old 08-23-2022, 10:13 AM
Smith Bros pushrods are pretty good, and pretty affordable. Butler sells them in lengths of .050.
Some people prefer thicker wall ones, or larger diameter which requires changing the guide plates.
Old 08-23-2022, 10:14 AM
Rev limiter? Do you think you over-revved it?
Just to say, over-revving is generally not a cause of bent pushrods.
Old 08-23-2022, 10:38 AM
grivera's Avatar
Here it indicates he was planning Lunati (unknown specs) pushrods...https://forums.maxperformanceinc.com...&postcount=165
Hopefully you get this all resolved with minimal damage!!
Will Rivera
Old 08-23-2022, 10:45 AM
64speed's Avatar
Yeah I over revved it. I missed 3rd and it hit about 7000. Caster1 has almost exact engine in his car and has no problems from it. I am pretty sure I over revved it and that was it. It holds 10 pounds at idle even coasting down the road and ran fine other than a skip from the dead cylinder. I am hoping I can drop the pan, clean it out, put lifter and pushrods in and seal it back up.
Old 08-23-2022, 10:54 AM
Lifters probably came out of the bores.
Like I said, over-revving rarely causes a problem like this.
Old 08-23-2022, 11:31 AM
grivera's Avatar
It holds 10 pounds at idle even coasting down the road...
What was your oil pressure prior to this issue?
Will Rivera
Old 08-24-2022, 10:03 PM
64speed's Avatar
25-30 hot at idle
Old 08-23-2022, 11:02 AM
More red flags from that post....
Block and all parts except for pushrods, gaskets (except head) and cam bearing are going to machinist Tuesday. We have worked out a deal I’m not gonna get in a hurry and give him until midsummer and in exchange he is gonna align bore the crank and came tunnel, fit the studs to main caps, assemble pistons to rods and ring the pistons, degree cam, zero deck block, do all the cylinder bore and home and everything else that goes into it including assembly and testfire and break in for 1600. He will be providing the Lunati pushrods, oversized cam bearings, and all gaskets except for head. I think that’s a hell of a deal. What are your thoughts?
Old 08-23-2022, 11:11 AM
Looks like he's a Chevy/Chry/Ford guy:
http://www.cmengines.com/Engines/Str...5/Default.aspx
Old 08-23-2022, 11:21 AM
Wow, more than a few left crappy reviews:
https://www.google.com/search?q=caro...lient=gws-wiz#
Old 08-23-2022, 10:25 AM
Nobuddy Nobuddy is offline
Is this the engine with big Chevy rockers because the machinist determined Pontiac rockers had incorrect geometry?
Old 08-23-2022, 10:43 AM
I missed that point, what's the post # on that? Or different thread?
Nevermind:
https://forums.maxperformanceinc.com...d.php?t=831609
