Old 08-10-2023, 05:51 AM
64speed's Avatar
64speed 64speed is offline
I have a slight and I mean slight leak at the top of the timing cover on the passenger side where the timing cover meets the block right by the bolt hole. I had to take the bolt out to put the brackets on. Do I need thread sealer or what?
Old 08-10-2023, 05:54 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
SO glad to hear that it's running again! Enjoy!
Old 08-10-2023, 06:33 AM
Well all the holes related to holding on the timing are, or should be blind unless they where at some point repaired and drilled too deep.
To be safe just put some sealer on it and then re-tighten down all the 4 bolts and two stud nuts that hold the cover on.
Old 08-10-2023, 07:26 AM
64speed's Avatar
Little tinkering left but I think it’s actually better for me than the roller. It’s a long way to the top if you wanna rock and roll ��
The Following User Says Thank You to 64speed For This Useful Post:
Old 08-10-2023, 02:49 PM
64speed's Avatar
So the leak resolved itself so I won’t look a gift horse in the mouth. Clutch is sticky coming up which I assume is air still in the line. It was a pain getting any pedal at all and then over night it got worse. So I’m thinking air moved around????
Old 08-10-2023, 02:53 PM
64speed's Avatar
https://youtube.com/shorts/tFebY_Tq3YE?feature=share
The Following 2 Users Say Thank You to 64speed For This Useful Post:
Old 08-10-2023, 03:02 PM
Gach's Avatar
Gach Gach is offline
Whoo that sounds good, god thats a gorgeous car.
The Following 2 Users Say Thank You to Gach For This Useful Post:
Old 08-12-2023, 03:37 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Originally Posted by 64speed View Post
Car looks and sounds great, hopefully the 3rd time is the charm
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 08-10-2023, 03:39 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Gach is right thats a beauty, car is excellent love the post coupes myself. what dash is that and also what sound deadener did you use on the floor?
Old 08-10-2023, 03:40 PM
JSchmitz's Avatar
Looks and sounds great!
Old 08-10-2023, 03:46 PM
64speed's Avatar
Dakota Digital RTX. That is Amazon brand sound deadener. 50 bucks for enough to do the whole damn car
Old 08-10-2023, 04:30 PM
NeighborsComplaint's Avatar
Sweet car! Sounds just as rowdy at idle as it did with the roller cam. You're going to enjoy that car.
Triple Black 1971 GTO
Old 08-10-2023, 04:38 PM
64speed's Avatar
It’s nasty. Actually thinking of quieter mufflers. I am a music lover and I can’t hear anything in the car
Old 08-10-2023, 04:39 PM
64speed's Avatar
I think my thermostat is sticking. It is a 180 but it’s going to 210 then coming down and going back again and on and on
Old 08-10-2023, 04:49 PM
grivera's Avatar
grivera grivera is offline
Don’t change the mufflers till you get carpet and a full interior in there as it will muffle the sound a bit.
Is the upper radiator hose hot at 180 (test with infrared gun)? Also, not sure if you’ve done so but I check every thermostat in a pot of water with a thermometer before install - so far above 50% don’t open at advertised rating - more like 10-15 degrees above it.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 08-10-2023, 05:14 PM
I’m glad to see things have finally come together.
Dr. Thomas Sowell
Old 08-10-2023, 06:11 PM
Gach's Avatar
What I can’t hear you…LOL trust me I know the feeling.
Old 08-10-2023, 06:14 PM
Gach's Avatar
Its a new start up, might just be working air out. Hopefully it will stabilize.
Old 08-11-2023, 10:33 AM
64speed's Avatar
I have to get different mufflers, I can’t go thru a drive thru without cutting it off LOL. My FIL came last night and the first thing he said was it’s loud
Old 08-11-2023, 10:50 AM
Dynomax Super Turbo is the go-to, you might be able to get a 20" case under there, but 18" will definitely fit.
