Old 02-22-2018, 10:39 PM
Nice article. Matches a lot of the info I received in a couple of Fuels and Lubes Engineering classes years ago.
Quite a bit more info on the different anti detonation tools out there like the water meth kits. Thanks.
  #42
Old 02-23-2018, 11:28 AM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Typical race fuel dealer propaganda about avgas.
Less said,,,,,,,, Less mended.
  #43
Old 02-23-2018, 12:24 PM
Mike Davis's Avatar
Mike Davis Mike Davis is online now
What most don't understand is you have to add a Pitot Tube to actually measure how much better the car runs on AV gas. If you also add a Altimeter and reset 0 at +2500ft you should not have any problems because the car thinks it's at 2500 feet instead of sea level.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #44
Old 02-23-2018, 02:16 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
OP, what has transpired with the builder since you last posted?
  #45
Old 02-23-2018, 03:42 PM
Navy Horn 16 Navy Horn 16 is offline
No, no, no. Set it to like -1000 feet and you will pick up some serious HP from the denser air.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
  #46
Old 02-23-2018, 03:49 PM
Mike Davis's Avatar
That would be for the heads up guys.
Street guys need to be around 2500ft, also need carb heat on and the mixture set rich so not to freeze up.
421 CID
  #47
Old 02-23-2018, 08:05 PM
ERIC AULL ERIC AULL is offline
BULL DINKY!
  #48
Old 02-23-2018, 09:08 PM
Pretty much. We ran 100LL in all our fuel trucks. It had to be nearly zero degrees before there were any cold starting problems.
Dr. Thomas Sowell
  #49
Old 02-23-2018, 09:15 PM
Originally Posted by U47 View Post
For you maybe. I liked them, working on them, and put many hrs. in the air with them.
http://vp23.org/gallery_gen/f639849f...2c_gallery.jpg
P2V Neptune....2 turnin’, 2 burnin’! An old friend of mine was the crewchief on the Super Connie “Fish” Salmon bought the farm in. The FAA stated the reason for the crash was the pilot’s and co-pilot’s fixation on the fire warning lights( common on Connies and DC-7s during takeoff and climb out) instead of maintaining proper airspeed and altitude. PRTs would glow white hot during full throttle.
Dr. Thomas Sowell
  #50
Old 02-24-2018, 10:54 AM
billkinney billkinney is offline
Sorry I've been out. Shoulder surgery OUCH!
He said there were 6 valves that were sticking. after I removed the valve debris and reinstalled the head I rolled it over several times and all valves seemed to work just fine. I've decided to rebuild my old but not original engine. He'll pay me back one way or another.
You guys are a wealth of information. Thank Yall
  #51
Old 02-24-2018, 11:07 AM
P.S. I had to take the car to his shop shortly after the install because the internal dipstick tube was wrong (couldn't check the oil). At that time he noticed the pushrods were hitting the head and installed longer ones. Could this help in your diagnoses ?
  #52
Old 02-24-2018, 02:44 PM
TinInjun's Avatar
Find a new engine builder, this guy has no idea what he is doing.
  #53
Old 02-24-2018, 10:48 PM
Pushrods hitting the heads? WTF does that even mean?
Bill Nye.
  #54
Old 02-25-2018, 03:09 AM
X 2!
Dr. Thomas Sowell
  #55
Old 02-25-2018, 01:38 PM
I was wondering the same thing...1.65 ratio rockers in a head that hasn't had the holes elongated? Even so.... longer pushrods?
Old 02-28-2018, 08:26 PM
Talked to a lawyer today.. Damnit! 1 expert witness and a lawyer eat up the cost of a n ew motor on day 1. Needs an ass whoopin
  #57
Old 02-28-2018, 11:58 PM
64speed's Avatar
64speed 64speed is offline
Where are you located at? I have two expert engine builders in SC that I found thru extreme research. One is Carolina machine engine www.cmengines.com the other is wayne Skess at Greenwood autoparts.
  #58
Old 03-01-2018, 12:02 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Bottom line is, the jackleg builder is taking premium money and blaming his fu&kup`s on fuel that he knows nothing about.
  #59
Old 03-01-2018, 12:36 AM
How much does a full page article in the local newspaper cost? There is more than one way to split this atom. Let him choose between making it right and you ruining his business.
  #60
Old 03-01-2018, 08:43 AM
I'm in south Florida and the case would be in Maryland
