Old 03-19-2018, 03:24 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
Default fan shroud
what determines if 65 gto had a fan shroud and or fan guard mine had neither. was that sometimes the case or never. I would like to install a fan shroud and one has come available to me before I buy i wanted some thoughts
Old 03-19-2018, 09:52 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
All 1965 GTO’s came with the top finger guard, except for an air condition optioned car.
The AC cars required a full metal fan shroud. The finger guard did not come with the shroud.
There was another factory fan shroud made of a thick fiber plastic #9774621. This was used for the trailer package or field-installed AC.
Pontiac GTO restoration guide, page 366.
Old 03-19-2018, 10:16 PM
72pontiac's Avatar
thanks i always forget about my restoration guide
Old 03-20-2018, 04:55 PM
geeteeohguy's Avatar
And the '65's with AC (and a fan shroud) had a different height radiator core. So if you upgrade to a shroud, you'll need to find an aftermarket one for a non-AC radiator, which is 2" shorter at the core.
Jeff
Old 03-20-2018, 05:09 PM
72pontiac's Avatar
Makes sense.I know it would help cooling efficiancy. Not as concerned with authenticity. I guess fan size would matter too. Going to ask the seller for more info.
Old 03-21-2018, 01:02 PM
72pontiac's Avatar
Decided against it. terrible reviews on the part. Not originally equipped with one anyway. What worked in 65 should work in 2020
