Old 04-14-2018, 12:31 PM
bird72's Avatar
bird72 bird72 is offline
Originally Posted by Norwood View Post
I find this story very hard to believe. 9 miles when he got it. That would be at most maybe 10-12 times down the track. “1/4 at a time “. First you need to get to the line then go 1/4 then shut Down a 1/4 then drive back to your pit. Not buying the story or the car. Lol
X2
Although that PHS is a mind blower for sure. But present pimped engine is not even period visual historic attempt.
72 Bird
  #3062
Old 04-14-2018, 01:44 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
I thought it was kinda cool.....till I saw the back seat......rear suspension....and engine.......Three strikes.....and Yer' OUT...:
Looks very well done.....but I don't see anybody coming to the party with 50k........20 maybe......
  #3063
Old 04-14-2018, 02:23 PM
Formulabruce's Avatar
No Going around corners over 10 mph either!
  #3064
Old 04-14-2018, 06:07 PM
T/A addict T/A addict is offline
Default OK School me on Carb and intake
I've been needing a carb for my 455 HO for a while. I finally broke down and bought a Holley 4150 DP a while back expecting it to be a quick easy swap... what do ya know... that's not gonna happen. I pulled off the carb that was on it and didn't even really notice the issue until I tried to put the new carb on----damnit.
Ok so I'm going to assume that this is the stock intake correct. There are obviously differences in the carbs.... mounting tab locations, butterfly location - which will never work, etc.
So what are my options for a carb then?
Untitled by Jeff, on Flickr
  #3065
Old 04-14-2018, 06:30 PM
77 Canamman's Avatar
Spreadbore to squarebore adapters are available to allow the carb to be mounted to that intake. Unfortunately it will throw off the shaker height, and it does not address the choke, throttle hookup, etc..
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #3066
Old 04-14-2018, 07:24 PM
This is REAL easy....
Just find a CLEAN 1972 Pontiac Quadra-jet.....400 and 455......They are identical cosmetically....
Put a kit in it...and get some bigger jets...if you need them......or send it out to a Q-jet guy....
It will fit properly......work as well as the holly........but won't leak raw fuel all over your hot intake...and set your car on fire...
A properly set-up Q-jet....will easily get your HO....in to the 12's......if the rest of your car can keep up...
  #3067
Old 04-14-2018, 11:52 PM
IMHO, If its going to be a regular driver, get a 77-79 Pontiac or Buick 800 CFM Q-jet. These carbs have whats called APT, which is under a plug below the 4 inch air cleaner gasket. This allows to "richen" the Idle mixture and smooth out the engine with the gas we have. Cliff recommends 'em and they are an excellent choice for a non original carb usage. Mine was rebuilt by a member here and adjusted and installed in 2006 and has not been touched since. As Cliff says, it "runs like fuel injection"
  #3068
Old 04-15-2018, 04:05 AM
Kenth's Avatar
Kenth Kenth is offline
APT adjusts the main circuit not the idle circuit.
The idle circuit is a separate stand alone circuit adjusted by the idle mixture screws in the throttle plate.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
  #3069
Old 04-15-2018, 07:29 AM
They will need idle tube and jet/rod changes to richen them up from the smog calibrations, but they are a super piece-far better than any Holley.
  #3070
Old 04-15-2018, 08:18 AM
Yup, My Idle circuit was opened up, and the PART throttle adjusted with APT.
Cars run better with ethanol in the fuel with these carbs...
thanks for the correction
  #3071
Old 04-15-2018, 08:59 AM
I knew about the adapters but ruled that out immediately due to shaker clearance...
I have ordered Cliff's book incase I take the rebuild/modify route myself.....
I do have a Q-jet from a '79 403 if that can work good
I saw this for a '72 carb.. https://www.amazon.com/ROCHESTER-CAR...uretor+pontiac
also a service like this...http://quadrajetpower.com/quadrajet-...pecific-needs/
The 2 links would be stressing the budget out but I'd like to do it right and do it once.
  #3072
Old 05-27-2018, 11:54 AM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
https://orangecounty.craigslist.org/...589511701.html
  #3073
Old 05-27-2018, 12:04 PM
RamAir's Avatar
RamAir RamAir is offline
Another 100 g’s and it should be good as new
  #3074
Old 05-27-2018, 12:59 PM
Nice.....just needs......everything......except for the A pillar trim...
  #3075
Old 05-27-2018, 01:05 PM
poncho4554spd poncho4554spd is offline
I saw that one about a week ago. Gonna need a lot of TLC and a whole lot more money.
  #3076
Old 05-27-2018, 02:00 PM
giles's Avatar
giles giles is offline
I’m not sure the seller has even looked at his own pictures;
“The body is in decent shape” - the quarter and trunk floor have holes I could fit my fist through!
“It has been sitting for nearly 25 years” - the tabs say ‘85, and by my count that’s 33 years
  #3077
Old 05-27-2018, 03:42 PM
necdb3's Avatar
necdb3 necdb3 is offline
I think that was one of the 4 or 5 early 70's T/A's that was for sale in Daytona Florida a year or so ago. Looks very familiar.
  #3078
Old 05-27-2018, 06:27 PM
This one sure is.... interesting.
Cool original specs: 455 HO, 4-speed, posi and nothing else, plus original window sticker
Unfortunately a lot of its "originality" is gone
https://www.ebay.com/itm/1971-Pontia...5aylBx&vxp=mtr
Most recent eBay listing ended May 20 - had it starting out at 29,500 - ended with 0 bids.
First eBay run was listed for 55,000
Its really going to be hard to sell that car above 15,000
  #3079
Old 05-27-2018, 07:42 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
I wouldn't think twice about parting it out and scrapping the rusty carcass. Some must die so others can live and that car is a perfect candidate. Can't save everything!
  #3080
Old 05-27-2018, 11:01 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
I think we all agree it's too far gone for even thinking about restoration. It's missing a lot and what is there is in bad shape. Engine, Trans & Rear End salvageable...probably?
My fears are some crook will strip out what can be re-used, cut the numbers out of it, re-body it in something else and dupe some poor guy out of his money thinking he just got a great deal on a rare Pontiac muscle car for $40,000 + dollars. Probably oughta remember this one's VIN.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
