Old 04-30-2018, 01:33 AM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Default Deck dimensions / blueprint
Hi there, getting a torque plate made over here in NZ, couldnt find one locally and really dont want to ship one 1/2 way accross the world!.
I have measured off a couple of sets of heads but am getting small errors that dont seem to add up for bolt holes and bolt offset from bore.
I have input the data into CAD, but would like to check a few key dimensions off the original design if possible, happy to return a.dxf file if anyone only has scans or paper copies for the favour.
Cheers Don
Working on going faster (and now staying dry at the same time !!)
Old 04-30-2018, 03:35 AM
gavin gavin is offline
I made mine off a head gasket and it works well. The main hassel is to get the location holes right. I used 1 1/4" gas cut a wee bit small I then drill all the holes and bolted on to a block .I then got the engine shop to bore it on the block indexed off the bores 090 bigger than a 455 bore. It works pretty good.
Old 04-30-2018, 06:02 AM
krisr's Avatar
krisr krisr is offline
Hey mate, if you want to send me the DXF file, i'll check your dimensions against a 64 block I have downstairs if you'd like. I've been meaning to draw up a torque plate myself for any engines that I do now as no machine shops over here have one in AU. What did you use as your datum? the front or rear of the block?
Old 04-30-2018, 12:39 PM
RA462's Avatar
RA462 RA462 is offline
I have this picture I saved from somewhere. I don't know how accurate the measurements are but if I remember correctly it came from Cometic. Hope it helps.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 04-30-2018, 07:50 PM
azbirds's Avatar
azbirds azbirds is offline
I also used a head gasket to make mine. Made it out of 1.5" 6061 plate with a bore of 4.375. Worked great.
When people tell me they HAD to sell their car when they started a family, I show them the three car seats in the back of my 69Trans-Am..............and we didn't even use car seats back then!!
Old 05-01-2018, 01:21 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by RA462;5876841 ...
I have this picture... if I remember correctly it came from Cometic. ..
Yes, that's the one I posted that's from Cometic. It's accurate. This image might be a little clearer.
But that page doesn't totally show dowel locations, so here's the other page. Note the subtle .010" difference in dowel locations.
ID:	482104   Click image for larger version
Old 05-01-2018, 09:34 PM
455-4+1's Avatar
Thanks guys, will make a few adjustments to my file and see how it goes
Old 05-11-2018, 08:09 PM
tc's Avatar
tc tc is offline
A little late, but here is what I measured from my block
Name:	428 block.jpg
Old 05-12-2018, 03:21 AM
455-4+1's Avatar
Cheers, pretty sure i got things sorted. Thanks for the images, i to making chips 😁
Old 10-15-2025, 08:34 AM
Tracy G Tracy G is offline
Default Pontiac cylinder and head stud locations
DO anyone have the pontiac cylinder and head stud locations?
Old 10-15-2025, 08:36 AM
Thank You!
