Hi , what shade of black for the hideaway doors , brackets and linkage? Thanks
67428HO |
What year?
Backside brackets, etc would be 60% gloss. on the 68's the grills are argent silver (like the rally II wheels. black in-between & backside of the fins of the grill are closer to the sheen of bare plastic. 30% give or take. semi flat I would say. I have lots of pictures of my 68's finished & I matched an untouched original. 69's I am unsure on the grills, but the brackets would be the same as 68
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
68"s Also what's the difference in the buckets, between a hideaway and non hideaway? Ames catalog says headlight trim rings will not fit right side with hideaways. why? Thanks.
67428HO |
buckets & rings are the same between hide-aways & std, but left & right side are different on the rings, & the buckets get even screwier. Hi/Low & left/right specific as I recall.
Here are picks of my hideaway headlight assemblies after restored. Trim rings all appear to be the same. Buckets for R and L are different because of the spring location. Top tab of the buckets are stamped with K (outer) and J on (inner) on Right assembly; A (inner) and B (outer) on Left.
I used semi-flat, closer to 30% gloss when I painted these years ago. 60% gloss may be more correct. Hope this helps.
Don't rush me - it's only year 20 of the 3 year restoration! 68 GTO convertible YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track, P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways C1 224 Triple white |
Thanks for the info!
67428HO |
